Ordering a single bearing...
#159548
12/01/08 12:01 PM
12/01/08 12:01 PM
Posts: 1,943 San Angelo, Texas, U.S.A.
1968RR
I was putting together a short block this weekend, and I broke a no. 2 piston ring and scored a rod bearing. Summit will let me order a single ring set, but I can't find anyone who will let me order a single rod bearing set. I'm trying to get a matching bearing (Sealed Power part no. 7135CH-10). Anyone know a place that'll help me out? Thanks in advance.
"When I'm in a slump, I comfort myself by saying if I believe in dinosaurs, then somewhere, they must be believing in me. And if they believe in me, then I can believe in me." - Mookie Wilson
Re: Ordering a single bearing...
[Re: MoparforLife]
#159550
12/01/08 12:17 PM
12/01/08 12:17 PM
1968RR
The engine is already balanced, but I guess any difference in bearing weight would be negligible. BUT would the difference in the softness of a different brand/type bearing have any effect?
[Re: 1968RR]
#159551
12/01/08 12:21 PM
12/01/08 12:21 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
you won't notice any difference in them. In fact I wouldn't doubt that they may come from the same place in different boxes. Many are the same vendor, can't remember which other than Clevite and Michigan. As for balance they will not effect that at all.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
