eldlebrock 800 avs #159423
11/30/08 09:15 PM
11/30/08 09:15 PM
under the hood
A47 Offline OP
A47  Offline OP
under the hood
just about to stick a thunder 800 avs on my 440 ..have got a weiand 8009 stealth intake ..that i was going to use also , do i need a insulating spacer...... if so what one?
appreciate any help
Re: eldlebrock 800 avs [Re: A47] #159424
12/01/08 12:25 AM
12/01/08 12:25 AM
ILL
mark7171 Offline
mark7171  Offline
ILL
Went and got a "Quality" phenolic 4 hole from 4secondsflat.com and use it on my ported 8009 . The 8009 should be a action+ good to 4,800-5000 rpm or so. Mine is topped with a 800 avs thunder also ,and drives with fine street manners. I don't know what you got, or what youre doing. you might likee fthe performer.
good luck.
Re: eldlebrock 800 avs [Re: mark7171] #159425
12/01/08 02:58 AM
12/01/08 02:58 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
I don't have the space for a spacer on my RPM on a 383 with a stock hood on '70 RR just using a gasket, works fine.
We have well over 100*+ weather here
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: eldlebrock 800 avs [Re: R70RUNNER] #159426
12/01/08 10:09 AM
12/01/08 10:09 AM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
Re: eldlebrock 800 avs [Re: 69Cuda340S] #159427
12/02/08 07:39 AM
12/02/08 07:39 AM
under the hood
A47 Offline OP
A47  Offline OP
under the hood
thanks Guys ..for the help & advice it has been appreciated
