Re: Quick Swap 318 to 383
[Re: Copper Dart]
#1593587
03/16/14 11:27 AM
03/16/14 11:27 AM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
Yes, it does help. More pictures for those of us that don't like reading On to the transmission, driveshaft (from a '67 Coronet 318 727) install and linkage Edit: We used the trans crossmember from the '67 Satellite 904, just turned the mount around.Edit
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: Copper Dart]
#1593588
03/16/14 11:31 AM
03/16/14 11:31 AM
Copper Dart
No exhaust to install, I will have that done at a shop. Back up top to finish the install.
[Re: Copper Dart]
#1593595
03/16/14 11:53 PM
03/16/14 11:53 PM
Copper Dart
Valve covers painted and installed. The Duralast cut to fit wire set #1600 (90* plug boots) and #1601 (straight boot) worked better than expected! $15.00 each set Running nice. I have to get the exhaust system done, I will try and find a shop tomorrow AM if possible.
[Re: Copper Dart]
#1593597
03/24/14 02:35 PM
03/24/14 02:35 PM
Copper Dart
loaded on the trailer on the way to get the exhaust installed
[Re: Copper Dart]
#1593599
03/24/14 02:46 PM
03/24/14 02:46 PM
Copper Dart
A WOPPING $800. later OUCH! I bet I could have ordered it from summit or jegs for half that. Can you say "Bait and switch"?. After loading everything up on a trailer and dropping it off, knowing I had to have it done today, or I wouldnt have taken it to a shop. I would have done it myself.
[Re: Copper Dart]
#1593600
03/24/14 02:51 PM
03/24/14 02:51 PM
Copper Dart
I had to change out the intake manifold and carb. That old 2 bbl was giving me too much trouble, hard to start, popping/coughing on acceleration, unstable idle etc.... Now it lights right off. I have to modify the throttle cable and kick down bracket to work properly and I still have to work on the bog issue but that will be for another time.
[Re: bobbyb]
#1593603
03/25/14 03:35 PM
03/25/14 03:35 PM
Posts: 7,831 east side of Ohio
basketcase
east side of Ohio
just a TAD pricey. I've got a couple of shops around here, and none would have charged half that. car looks great
1981 Dodge D150 360 auto
[Re: basketcase]
#1593604
03/25/14 05:53 PM
03/25/14 05:53 PM
Posts: 5,161 CT
GTX MATT
CT
Man you could have gone TTI for that kind of dough. Cool though! I have a '67 Lite that was similar to yours when I got it. 383 is a great engine for a nice cruiser and driver. Nice car
[Re: GTX MATT]
#1593605
03/27/14 10:14 AM
03/27/14 10:14 AM
Copper Dart
I'm not very happy to say the least. He said it would run me $600 tops out the door. After loading it on the trailer and driving across town and dropping it off as agreed, I get a call, "its going to be a bit more, do you still want to get it done?" Thats why I said "Bait and Switch" just the cost of going to pick it up without having it done and wasting the day too, I figured the $200 was worth not having to deal with finding another shop or having to install TTI's system a week or two later myself. Some business are not being run like they were some years ago where your word meant something. The job was not done quite the way we agreed. It was supposed to be "serviceable" Un-bolt it to remove....NOT! some (not all) of the hangers have to be cut off Lesson learned (I hope)
