904 with a low gear set I bet would get you a couple of tenths. A low gear set in your 727 would put it in the 9's for not too much money. I personally would rather do it with no overdrive. Less weight and one less thing to go wrong. Seems like Murphy chases me around at times. Lol
I concur...low gear set 904 and matched coverter and forget the OD BS....
If you can't handle the truth, you're living a lie.......
