70 HEAT RISER REBUILD QUESTION? #1588613
03/05/14 09:00 PM
03/05/14 09:00 PM
N.W. INDIANA
moparjohn Offline OP
N.W. INDIANA
On 1970 Mopars are the shafts for the heat riser all the same between small block and big block? Or is everything differant?
Thanks!
Re: 70 HEAT RISER REBUILD QUESTION? [Re: moparjohn] #1588614
03/06/14 09:31 PM
03/06/14 09:31 PM
Maple Valley, WA
70mopes Offline
70mopes  Offline
Maple Valley, WA
Depends on what you are talking about. 340 shafts are shorter than big block and I believe 318 heat riser shafts since 340 shaft does not extend through both sides of the manifold. Bushings are different between 340 and big block too. You can shorten a big block shaft to work in a 340 application.
