Best Electric Fan stock radiator #1587958
03/04/14 12:11 PM
03/04/14 12:11 PM
Northampton Pa
65 NSS 500 Offline OP
Northampton Pa
I was curious what electric fan would install on stock radiator. Will the ones with the poke through hold down work on a stock radiator? I am looking for something that I don't have to make brackets. Any suggestions are appreciated .
1965 Coronet 500 340 40+ Passon 4sp 12.90 2.6 60' street tires
Re: Best Electric Fan stock radiator [Re: 65 NSS 500] #1587959
03/04/14 12:41 PM
03/04/14 12:41 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
One for a Chevy HHR. Thin, draw low amps, built in shroud.
Re: Best Electric Fan stock radiator [Re: 65 NSS 500] #1587960
03/04/14 12:55 PM
03/04/14 12:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Amps in a electric motor is the HP(more HP more amp
draw).. look for a fan that has the outer ring around
the blades.. thats called a spill ring.. with it makes
for a more efficient fan... the HHR fan is what I run
on my Rampage because it has a shroud that fit my rad
and is a good fan... so far on the street its been great
Re: Best Electric Fan stock radiator [Re: TheOtherDodge] #1587961
03/04/14 01:53 PM
03/04/14 01:53 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
This..............cools my big block in the summer heat. Plus the fans that go through the radiator do more damage(to the fins)than good............
Re: Best Electric Fan stock radiator [Re: Thumperdart] #1587962
03/04/14 02:41 PM
03/04/14 02:41 PM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Chevy HHR fan on mine as well, and it works great.... but it does pull quite a bit of amps. If I recall correctly it takes 35-38 amps to get the fan moving and 15-18 amps once its on.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Best Electric Fan stock radiator [Re: FlyFish] #1587963
03/04/14 06:43 PM
03/04/14 06:43 PM
Houston, Texas
Houston, Texas
Do you run a relay?
Re: Best Electric Fan stock radiator [Re: TheOtherDodge] #1587964
03/04/14 06:52 PM
03/04/14 06:52 PM
Northampton Pa
Northampton Pa
That's for the input. Does anyone have a picture. I tried to look up on line but cant find one. I am trying to see how it would attach.. Looks like the HHR one is the way to go..
Re: Best Electric Fan stock radiator [Re: TheOtherDodge] #1587965
03/04/14 06:58 PM
03/04/14 06:58 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Do you run a relay?
The best and proper way is w/a relay................
Re: Best Electric Fan stock radiator [Re: Thumperdart] #1587966
03/04/14 07:59 PM
03/04/14 07:59 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If you're using a stock shroud with the radiator it's easy. Make 2 straps from 1/2"X.060" steel the width of the radator. They will go across the radiator and be held on with the fan shroud bolts. Bolt the fan to these straps. Hidden from view and inside the stock shroud.
Doug
Re: Best Electric Fan stock radiator [Re: TheOtherDodge] #1587967
03/04/14 09:33 PM
03/04/14 09:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Do you run a relay?
Yep... basically if its 10 amp or more I put it on
a relay and the relay is near the item it will power
EDIT
here is the HHR on my radiator... this is on my street
Rampage
