1970 E-body Emergency brake spring retainer
#1587402
03/03/14 02:23 PM
03/03/14 02:23 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hello All, Trying to help another buddy on his '70 'Cuda. On the emergency/parking brake mechanism, there's the plastic/fiber retainer the holds the return spring in place so it doesn't go through the rod hole. Does anyone sell these? Or, is one at the mercy of trying to find an original and hope it is good?
Thanks in advance
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: 1970 E-body Emergency brake spring retainer
[Re: hemi68charger]
#1587403
03/03/14 04:19 PM
03/03/14 04:19 PM
Posts: 21,455 It's a dry heat
gtx6970
It's a dry heat
correct ones are not avail. cut the end off of an old firewall insulation pad nail and use it see attached Alan Gallant gave me the idea.
[Re: gtx6970]
#1587405
03/03/14 04:28 PM
03/03/14 04:28 PM
gtx6970
It's a dry heat
Just remove the pull rod, replace bushing and re-install the rod with the correct tube rivet ( I had the rod and spring replated at Dynamic Renovation ) Then bought the rivets thru www.rivetsonline.comI have them at the shop if you need one
