'69 Dart sway bar #1586218
03/01/14 12:15 PM
03/01/14 12:15 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..what style bolt and nut was used for K frame brackets?
..standard bolt and nut with captive washer?
Re: '69 Dart sway bar [Re: can.al] #1586219
03/01/14 07:56 PM
03/01/14 07:56 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
On my 69 Barracuda Formula S with heavy duty suspensiona and 7/8" dia sway bar, the brackets were fastened to the K frame with bolts same as part number 13204 on page 104 here:
http://www.amkproducts.com/Catalog_PDF/92-108.pdf
except the maker's mark was B&H.
Hex nuts are the same as part number B-12782 on page 39 here:
http://www.amkproducts.com/Catalog_PDF/39-55.pdf
Re: '69 Dart sway bar [Re: kentj340] #1586220
03/01/14 09:33 PM
03/01/14 09:33 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
..tx for that info!
