Page 14 of 18 1 2 12 13 14 15 16 17 18
Re: Scratch Built Willys MB [Re: Defbob] #1586213
03/30/15 09:59 PM
03/30/15 09:59 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
splash shield for the air filter
Re: Scratch Built Willys MB [Re: Defbob] #1586214
03/30/15 09:59 PM
03/30/15 09:59 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
steering shafts cut to length
Re: Scratch Built Willys MB [Re: Defbob] #1586215
04/04/15 10:37 PM
04/04/15 10:37 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
rear shock towers arrived
Re: Scratch Built Willys MB [Re: Defbob] #1586216
04/04/15 10:38 PM
04/04/15 10:38 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Started making my rock sliders
Re: Scratch Built Willys MB [Re: Defbob] #1586217
04/04/15 10:38 PM
04/04/15 10:38 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
not as slick looking as I had hoped
Re: Scratch Built Willys MB [Re: Defbob] #1797782
04/07/15 08:28 PM
04/07/15 08:28 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
I trimmed the front of my rock sliders
Re: Scratch Built Willys MB [Re: Defbob] #1797785
04/07/15 08:31 PM
04/07/15 08:31 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
I also did away with the steering wheel disconnect and welded on a flange to eliminate as much play in the steering.
Re: Scratch Built Willys MB [Re: Defbob] #1797786
04/07/15 08:32 PM
04/07/15 08:32 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
I tack welded the shock towers in place
Re: Scratch Built Willys MB [Re: Defbob] #1797787
04/07/15 08:33 PM
04/07/15 08:33 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
My Smittybilt X20 Gen2 10K winch showed up, hooray!
Re: Scratch Built Willys MB [Re: Defbob] #1818071
05/03/15 10:59 PM
05/03/15 10:59 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
I didn't realized I never posted the winch mounted.
Re: Scratch Built Willys MB [Re: Defbob] #1818074
05/03/15 11:00 PM
05/03/15 11:00 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
I cut the hole for my alternator today. It's actually a very powerful supercharger...
Re: Scratch Built Willys MB [Re: Defbob] #1818432
05/04/15 01:24 PM
05/04/15 01:24 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Are you going to form and weld in a sheet metal bump to the hood, or leave the alternator exposed like that?
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Scratch Built Willys MB [Re: DusterDave] #1818491
05/04/15 02:19 PM
05/04/15 02:19 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Exposed
Re: Scratch Built Willys MB [Re: Defbob] #1819001
05/05/15 12:03 AM
05/05/15 12:03 AM
Byron, NY
W.I.N. Racing Offline
Byron, NY
hammer bondo should fix it!
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Scratch Built Willys MB [Re: Defbob] #1821258
05/07/15 07:30 PM
05/07/15 07:30 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
My Ruff Stuff diff covers and caliper brackets showed up.
Re: Scratch Built Willys MB [Re: Defbob] #1832921
05/23/15 07:16 PM
05/23/15 07:16 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
I pulled the cage out the other day to finish welding it. I also straightened out the pedal
Re: Scratch Built Willys MB [Re: Defbob] #1832923
05/23/15 07:16 PM
05/23/15 07:16 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Today I patched the rear of the tub.
Re: Scratch Built Willys MB [Re: Defbob] #1834894
05/26/15 10:37 PM
05/26/15 10:37 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Painted the cage and took the tub off the frame.
Re: Scratch Built Willys MB [Re: Defbob] #1834895
05/26/15 10:38 PM
05/26/15 10:38 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Then we set the cage back on the frame...
Re: Scratch Built Willys MB [Re: Defbob] #1834898
05/26/15 10:40 PM
05/26/15 10:40 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
I started the touch up work on the bottom of the tub.
