Page 16 of 18 1 2 14 15 16 17 18
Re: Scratch Built Willys MB [Re: Defbob] #1853854
06/21/15 04:17 PM
06/21/15 04:17 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Its back home grin
Re: Scratch Built Willys MB [Re: Defbob] #1854022
06/21/15 11:14 PM
06/21/15 11:14 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
I put the handles on to make it look better...
Re: Scratch Built Willys MB [Re: Defbob] #1854025
06/21/15 11:16 PM
06/21/15 11:16 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
I also tapped the vent hole for a 1/8" NPT fitting and started mounting the shifter assembly. With the Lokar shifter and the short Advance Adapters Th350 to Atlas adapter, I had to use longer bolts and mount the rear support in front of the flange instead of behind.
Re: Scratch Built Willys MB [Re: Defbob] #1854114
06/22/15 01:13 AM
06/22/15 01:13 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Looking good. You got some hours and a few bucks wrapped up in that puppy. up
Re: Scratch Built Willys MB [Re: Defbob] #1855479
06/23/15 08:38 PM
06/23/15 08:38 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
I got my 2/0 battery cables and my rear u-bolt skids came in
Re: Scratch Built Willys MB [Re: Defbob] #1858453
06/27/15 10:28 PM
06/27/15 10:28 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Tranny mount has been welded to the skid plate
Re: Scratch Built Willys MB [Re: NITROUSN] #1858455
06/27/15 10:29 PM
06/27/15 10:29 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Skid plate is painted and the drivetrain is installed
Re: Scratch Built Willys MB [Re: Defbob] #1858457
06/27/15 10:30 PM
06/27/15 10:30 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Body is installed
Re: Scratch Built Willys MB [Re: NITROUSN] #1858458
06/27/15 10:31 PM
06/27/15 10:31 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Cage is installed
Re: Scratch Built Willys MB [Re: Defbob] #1859294
06/28/15 11:11 PM
06/28/15 11:11 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Nose is back on
Re: Scratch Built Willys MB [Re: Defbob] #1859399
06/29/15 12:57 AM
06/29/15 12:57 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Very cool!
'63 Dodge 330
11.19 @ 121 mph
Re: Scratch Built Willys MB [Re: GY3] #1859977
06/29/15 09:48 PM
06/29/15 09:48 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Nipping away at it, a little at a time.
Re: Scratch Built Willys MB [Re: Defbob] #1863071
07/03/15 09:14 PM
07/03/15 09:14 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Dash is mocked up and front axle pulled for its rebuild.
Re: Scratch Built Willys MB [Re: Defbob] #1863073
07/03/15 09:15 PM
07/03/15 09:15 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Windshield is back and installed
Re: Scratch Built Willys MB [Re: Defbob] #1863075
07/03/15 09:17 PM
07/03/15 09:17 PM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Gears, Eaton E-locker, chromoly balljoints, high steer knuckle, and chromoly axle shafts installed. Ready for some paint.
Re: Scratch Built Willys MB [Re: Defbob] #1864917
07/06/15 08:52 AM
07/06/15 08:52 AM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Tom finished the front axle for me and I installed it.
Re: Scratch Built Willys MB [Re: Defbob] #1864918
07/06/15 08:53 AM
07/06/15 08:53 AM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
Now it is back on its wheels
Re: Scratch Built Willys MB [Re: Defbob] #1864919
07/06/15 08:55 AM
07/06/15 08:55 AM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
v-bands are welded to the headers.
Re: Scratch Built Willys MB [Re: Defbob] #1864920
07/06/15 09:00 AM
07/06/15 09:00 AM
Norwich CT USA
Defbob Offline OP
Defbob  Offline OP
Norwich CT USA
gas tank is installed and fuel system is just about finished. I also mocked up the tie rods to measure for the length of the sleeve.
Re: Scratch Built Willys MB [Re: Defbob] #1864937
07/06/15 10:29 AM
07/06/15 10:29 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Shaping up to be a very cool rig! Great job! thumbs thumbs
Gone to the dark side with an LS3 powered '57 Chevy 210
