suggestions/pics adding firewall / z-bar bracing #1582908
02/23/14 06:55 PM
02/23/14 06:55 PM
USA
SSAAHemiFan Offline OP
USA
Anyone have any clean ways or suggestions to ADD extra firewall bracing for 4 speed
How about any pics of beefed up or braced Z-bars ?
Just looking for ideas
Re: suggestions/pics adding firewall / z-bar bracing [Re: SSAAHemiFan] #1582909
02/23/14 10:30 PM
02/23/14 10:30 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
With the new technology in clutches there's no need for it
My last clutch was a old school Hays MarkXII plate with 2100# static pressure with 10 gram counterweights and I never had any fire wall issues. I did install a gusset under my dash from the pedal mount to the underside of the dash.I also modified my Z-bar to double shear at the clutch side with a rod end instead of that hokey razor sharp clip deal from the factory. I will be back down in the shop tomorrow and I will try to snap a pic for you.
Gus
64 Plymouth Savoy
Dana 60
Re: suggestions/pics adding firewall / z-bar bracing [Re: SSAAHemiFan] #1582910
02/23/14 11:23 PM
02/23/14 11:23 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
A piece of tubing from the firewall to the shock tower. A piece of plate to spread the load on the firewall. weld it or bolt in.
Doug
