Re: CLUTCH
[Re: BB65Barracuda]
#1582694
02/23/14 10:18 AM
02/23/14 10:18 AM
Posts: 21,084 Niles , Ohio
therocks
Niles , Ohio
X2 on the CF.Mine has been in 10 years at least.Still hooks like new.Rocky
Chrysler Firepower
Re: CLUTCH
[Re: 5spdcuda]
#1582696
02/23/14 02:50 PM
02/23/14 02:50 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
I'm sold on Centerforce. If light pedal pressure is at all a selling feature for you. Look no further.
Holding back power does not mean your pedal needs to be hard to push.
I'm tired of worn linkages, bending Z bars and flexing the firewall just because the last clutch was slipping. Not to mention the leg and knee of us older drivers.
Re: CLUTCH
[Re: AB&E]
#1582700
03/02/14 12:26 AM
03/02/14 12:26 AM
therocks
Niles , Ohio
I run an OE Timken tb I found.Works great.Rocky
Chrysler Firepower
Re: CLUTCH
[Re: therocks]
#1582701
03/02/14 03:32 PM
03/02/14 03:32 PM
Posts: 9,882 MI, usa
dvw
MI, usa
I run an E-body with a Center Force. It's the best clutch I've ever owned. No chatter, slip, pedal pressure is great. It's my wife's car. Small block 12.50@110Doug
Re: CLUTCH
[Re: AB&E]
#1582703
03/03/14 10:11 AM
03/03/14 10:11 AM
therocks
Niles , Ohio
When I got my CF it was a kit.Clutch PP and TOB.The car sat for a while after install and the TB made noise.Then my buddy at the parts store found a new Timken TB for me that sat on the shelf for like 8 years.No problems at all.Rocky
Chrysler Firepower
Re: CLUTCH
[Re: Quicksilver440]
#1582708
03/04/14 01:23 AM
03/04/14 01:23 AM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I know a few guys in the auto parts business what flywheel and spline do you have? Most stock type clutch kit companies don't offer an 18 spline unit. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: CLUTCH
[Re: fourgearsavoy]
#1582709
03/04/14 02:02 AM
03/04/14 02:02 AM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
Its a 23 spline....planning to buy the 11" jegs flywheel for $100 and a used scattershield (seems as cheap as a used bell and bottom cover).
Its going into a true daily driver with a real mild rebuilt 440. So pedal pressure needs to be where my 16 year old son and wife can drive it and not hate it. It will have a hydraulic master/slave if it matters.
Re: CLUTCH
#1582710
03/04/14 11:01 AM
03/04/14 11:01 AM
therocks
Niles , Ohio
If you run a hydro clutch you can run any PP setup.The hydro takes all the pressure.Its not like a mechanical linkage.The CF with mechanical link is an easy setup.Pretty much no pressure.I dont know how I could trust a 100 buck flywheel.Id have more faith in a stock wheel thats in good shape.The shield is a good idea.You know you can run a 10 1/2 clutch with a shield.Just need to move the starter in on the shield.Rocky
Chrysler Firepower
Re: CLUTCH
#1582711
03/04/14 11:06 AM
03/04/14 11:06 AM
Posts: 1,032 Ohio
dobie
Ohio
Yeah, Luk is actually about 5 minutes from me. I don't know of any store per se that carries them. Typically you have to know someone who works there.
Like I said, a neighbor and good friend of mine is an R&D guy there. He's offered several times to "hook me up" when I need a new package.
1968 Plymouth Road Runner
383 4 speed
