plastic epoxy weld.best to use? #1582400
02/22/14 12:08 PM
02/22/14 12:08 PM
sw michigan
TB3CUDA Offline OP
TB3CUDA  Offline OP
sw michigan
have a plastic gille with a broken piece what is the best plastic epoxy weld to use,only want to fix it once,i see j.b.weld has some,any body use it.
Re: plastic epoxy weld.best to use? [Re: TB3CUDA] #1582401
02/22/14 12:40 PM
02/22/14 12:40 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
Read this before you buy anything.....
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Jess
Yeah, it's hopped up to over 160...
