Sense you are changing everything. Headers bell housing etc. And you want something that will scream. You really should look at a R5P7. The cost would turn out roughly the same. You can run an adapter between the engine and your big block transmission.
Leon
what's the brand and is it cost effective for an adapter?
Mopar/Dodge NASCAR engine. Mopar block heads intake water manifold. The adapter plate and flywheel adapter runs anywhere from $500-950. More are to come. My designer is tied up at the moment.
