85 ramcharger. what does it weigh? 4300 today wo me
#1581631
02/20/14 02:22 PM
02/20/14 02:22 PM
RapidRobert
First (running) truck! SB/727/sure grip 9&1/4 (I believe),AC, monstrous 15" tires. do you have a rough idea of what this machine weighs? Thank you for your time. Adventurer
Re: 85 ramcharger. what does it weigh?
[Re: RapidRobert]
#1581632
02/20/14 03:20 PM
02/20/14 03:20 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
I've had four, my guess about 4,200. Seems like title weight was ~ 3,900?
Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: buildanother]
#1581634
02/20/14 03:45 PM
02/20/14 03:45 PM
3hundred
Colleyville
Whoops, now that you say that it looks like his is 4x4, all mine were 4x2
Robert
[Re: 73MagDuster]
#1581637
02/20/14 10:22 PM
02/20/14 10:22 PM
Posts: 1,159 Cruising!
QuickDodge
Cruising!
Shipping weight listed in the Standard Catalog of 4x4's for a base 1985 4x4 was 4315 lbs. This is data from Chrysler.
I don't think shipping weight includes fuel,oil,etc. So weight going down the road will be higher. These figures are useful for comparison purposes though.
[Re: 73MagDuster]
#1581638
02/20/14 11:41 PM
02/20/14 11:41 PM
Posts: 15,487 Florida
scratchnfotraction
my 85 2x stepside 318/nv4500/10bolt rear weighes 4382 +/- with me and 6 bags of trash in the bed every weekend at the dump going over the new scales.
my 88-440truck 440/727/8 3/4 weighes 3800 +/- with me 10 gallons fuel.
my 79 RC 4x4 6" lift 17/40/15 ground hawgs on 12" steel rims d44/d60 weighed in around 4800-5000 trail ready.
a stock 2x RC I would guess close to 4200-4500 depending on how loaded or striped it is.
[Re: QuickDodge]
#1581639
02/21/14 02:50 AM
02/21/14 02:50 AM
Posts: 10,590 Freeport IL USA
poorboy
Freeport IL USA
Shipping weight includes all fluid at correct levels with a couple gal of gas. But to a base model you have to add any options added to the base model, like AC or power steering. The extra stuff probably add up to the difference between a 4x4 and a 2x4. I'm guessing 4250 is going to be close. Gene
[Re: poorboy]
#1581641
02/21/14 04:11 PM
02/21/14 04:11 PM
QuickDodge
Cruising!
You could be right on how shipping weight is calculated. On several occasions, I've looked up shipping weight and then weighed an actual vehicle. In every instance, the actual weight has been at least 100 to 400 lbs. heavier than the shipping weight. Of course, if shipping weight only includes a couple of gallons of gas, a full tank of gas could add 75 to 150+ lbs. to the vehicle's weight.
For some reason, which I do not understand, the 1/2 ton pick-up trucks are often lighter than the Ramchargers.
[Re: poorboy]
#1581643
02/26/14 10:16 PM
02/26/14 10:16 PM
RapidRobert
"3hundred" was very close (4200). Drove it on a grain elevator scale. It was 4300 on the nose without me in it.
[Re: poorboy]
#1581644
02/27/14 03:15 AM
02/27/14 03:15 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Short box pickups don't have all the glass Ramchargers have, especially the later model ones. Glass is heavier then sheet metal and requires more metal structure to hold it in place. Gene
Good point. Strangely, the pickups had a 115 inch wheelbase compared to 108 for the Ramcharger & Trail Duster models.
