Indy Block Oil Line #1581339
02/19/14 05:33 PM
02/19/14 05:33 PM
England
fastfish451 Offline OP
England
Can you Indy Block users tell me the size of 2nd oil pick up line to port in block by oil pump I have a -12 from pan to Indy pump cover. cheers
Re: Indy Block Oil Line [Re: fastfish451] #1581340
02/19/14 06:37 PM
02/19/14 06:37 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
The oil port in the front of the block is 1/2" NPT.
Re: Indy Block Oil Line [Re: fbs63] #1581341
02/19/14 07:40 PM
02/19/14 07:40 PM
England
England
so no point going any bigger than a -8 line then. Anybody using this port thanks again
Re: Indy Block Oil Line [Re: fastfish451] #1581342
02/19/14 08:23 PM
02/19/14 08:23 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
1/2" "NPT" is a lot larger than 1/2". If you look at a 1/2" NPT to -12 adapter you'll find that they're virtually the same size. So, you want to run a -12 line to that port also.
Re: Indy Block Oil Line [Re: Stanton] #1581343
02/20/14 09:19 PM
02/20/14 09:19 PM
NC
440Jim Offline
440Jim  Offline
NC
A 1/2 pipe size will typically have an ID of about 0.840-2(.109)= 0.622".
Schedule 40 pipe, 0.109" wall thickness.
http://www.engineersedge.com/pipe_schedules.htm
A fitting may have smaller ID, depends.
AN hose can have different ID depending on brand, style, etc. AN-12 hose is roughly 0.688" ID, and again the fittings may have smaller ID.
