Re: Locked and Loaded for SGMP [Re: W8n2DustU] #1580200
02/18/14 02:14 PM
02/18/14 02:14 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Good luck w/that beast and make Mopar proud...............
Re: Locked and Loaded for SGMP [Re: Thumperdart] #1580201
02/18/14 03:05 PM
02/18/14 03:05 PM
jax. fla.
70Dustmite440 Offline
jax. fla.
I'm supposedly going to hang out for a day, not sure when yet but go get em!!!!
8sec. street car, been there done that. Quitting when your ahead isn't the same as quitting.
[img]https://scontent-atl.xx.fbcdn.net/hphoto...amp;oe=55DB3E4C[/img]
https://www.facebook.com/eric.norton.1048
R.I.P.UN.
Re: Locked and Loaded for SGMP [Re: 70Dustmite440] #1580202
02/22/14 01:30 AM
02/22/14 01:30 AM
Hot Rod Ridge
FastmOp Online tonguue
FastmOp  Online Tonguue
Hot Rod Ridge
NICE PASS!
Re: Locked and Loaded for SGMP [Re: FastmOp] #1580203
02/22/14 01:39 AM
02/22/14 01:39 AM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
NICE PASS!
Re: Locked and Loaded for SGMP [Re: tjmarcus1] #1580204
02/22/14 01:58 AM
02/22/14 01:58 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
NICE PASS!
NO ####!!!
Re: Locked and Loaded for SGMP [Re: W8n2DustU] #1580205
02/22/14 02:00 AM
02/22/14 02:00 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Best of Luck Marty.. hope it runs well for ya and
no reason to open the hood
Re: Locked and Loaded for SGMP [Re: J_BODY] #1580206
02/22/14 02:00 AM
02/22/14 02:00 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
he ran a 4.85 .
Jason digby also ran a 4.85 on leaf's .
Re: Locked and Loaded for SGMP [Re: a493demon] #1580207
02/22/14 10:10 AM
02/22/14 10:10 AM
Mo.
racerx Offline
racerx  Offline
Mo.
Didn't get chance to see Jason make his pass but i did see the black challenger go a 4.95 i think
Re: Locked and Loaded for SGMP [Re: racerx] #1580208
02/22/14 04:04 PM
02/22/14 04:04 PM
lancaster,california
johnnycuda Offline
johnnycuda  Offline
Good luck!
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: Locked and Loaded for SGMP [Re: racerx] #1580209
02/23/14 02:27 AM
02/23/14 02:27 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Marty made it in #32 out of 32. Rob Goss didn't make It in with his 440 gen 3 hemi 4.95 was his best, and Marty was bump spot at 4.85. Chad made it in with a 4.71 with his dart. Digby made it in leaf spring with his 69 dart.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Locked and Loaded for SGMP [Re: 1967dartgt] #1580210
02/24/14 10:40 AM
02/24/14 10:40 AM
San Angelo, Texas
W8n2DustU Offline OP
San Angelo, Texas
We have had nothing but converter issues. The PTC had 34% slippage. We ran 2 passes in second gear. Both were 4.96/4.97. Swapped to a borrowed Chance and went the 4.855 with 14% slippage. First round we had Marinis and thought we could go a low .70 after making other changes but had an issue staging. Bumping into the beams the car shut off when the power switch moved when bumping into the second beam. It was still a great experience. We may run OL275 this morning. We are qualified 26th in that class.
2010 Toxic Orange Challenger built by B and B Racecars! All aluminum R4/P5 engine, Proformance TH400 (3 speed) tranny, full Reid case, nodular 9" rearend, full Dragpak suspension, Protorque custom converter, BS3, PTE 85mm turbo, fire core wires, carbon doors, carbon front clip, and a whole lot more!
Re: Locked and Loaded for SGMP [Re: W8n2DustU] #1580211
02/24/14 11:28 AM
02/24/14 11:28 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Sorry for your troubles, hope you can get some rounds in ol275. Good luck. Mean Dean had a bad hotrod this weekend, number 1 qualifier 4.54.
Re: Locked and Loaded for SGMP [Re: W8n2DustU] #1580212
02/24/14 11:44 AM
02/24/14 11:44 AM
Wildwood, FL
1fastabody Offline
1fastabody  Offline
Wildwood, FL
Good Luck Marty, I stopped by and seen the car and have to say it is a work of art in person. I was there on Friday and Saturday and got to see the runs. I think once you get some of the bugs worked out that thing will fly. Go see the Pro Torque guys, they will hook you up!
Re: Locked and Loaded for SGMP [Re: 1fastabody] #1580213
02/25/14 02:11 AM
02/25/14 02:11 AM
Willow Spring
dagohman Offline
dagohman  Offline
Willow Spring
I watched some of the live feed, saw your car a couple times!!
I REALLY wanted to see it Friday, however we had some bad weather roll through!!
2013 we had one of the wettest yrs recorded in this area, 2014 seems to be following suit.
