2000 Durango code P1491 diving me nuts #158002
11/28/08 12:32 PM
11/28/08 12:32 PM
Hampton, Ga.
70dart360 Offline OP
Green Meister
Green Meister
Hampton, Ga.
My sisters Durango kicked on a CEL. O2 was weak and had a cooling fan issue. Replaced the 02, that codes gone now, but the P1491 was still there. Found the fan was shorted out and burned the B+ wire going to the relay. Fixed both issues, and now I can use a test light and ground the relay, fan kicks on fine if I make it. When running and you kick the a/c on no fan, pulling the pigtail for the coolant sensor wont kick it on either. All fuses are fin, swapped sme relays around, all them are OK too. Whats going on with this thing?
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: 2000 Durango code P1491 diving me nuts [Re: 70dart360] #158003
11/28/08 03:07 PM
11/28/08 03:07 PM
Grand Rapids, MI
Jim L Offline
super street
Jim L  Offline
super street
Grand Rapids, MI
Did you replace the fan motor itself? You need to check the PCM side of things too. You'll have to try and activate it on and off with a scan tool that is capable of doing that. The PCM pulses the ground to it.
Re: 2000 Durango code P1491 diving me nuts [Re: Jim L] #158004
11/28/08 03:34 PM
11/28/08 03:34 PM
Hampton, Ga.
Green Meister
Green Meister
Hampton, Ga.
Yep, the fan motor is new and i fixed the burnt wire. Monday I'll get print out of the computer harness out puts and put the scanner on it. Kinda what I was thinking, was just hoping it was maybe a common problem so I aint gotta go diggin in the harness or something.
Re: 2000 Durango code P1491 diving me nuts [Re: 70dart360] #158005
11/28/08 05:12 PM
11/28/08 05:12 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check the wiring harness under the battery tray. That is known to be a trouble spot.
Re: 2000 Durango code P1491 diving me nuts [Re: stumpy] #158006
11/28/08 05:50 PM
11/28/08 05:50 PM
Hampton, Ga.
Green Meister
Green Meister
Hampton, Ga.
I looked there due to some of the battery acid issues. Harness in clean, The fan will work if I ground the relay and thats the harness it goes through.
Re: 2000 Durango code P1491 diving me nuts [Re: 70dart360] #158007
11/28/08 09:09 PM
11/28/08 09:09 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
pcm grounds it internally .. probably fried the pcm good luck dan
Re: 2000 Durango code P1491 diving me nuts [Re: ph23vo] #158008
12/02/08 01:00 PM
12/02/08 01:00 PM
Hampton, Ga.
Green Meister
Green Meister
Hampton, Ga.
Bingo, found that to be the problem. Dang thing is $467 my cost at the dealer and it also has to be programmed for the truck, thats another $85. My sis bout fainted when I told her. Anyone had luck with boneyard computers?
Re: 2000 Durango code P1491 diving me nuts [Re: 70dart360] #158009
12/02/08 01:20 PM
12/02/08 01:20 PM
Columbus Ga
reflections7 Offline
Columbus Ga
I bought the computer for my 1999 Durango from a computer rebuild place on Ebay then send it already programmed when you give them the vin and Milage. Had it for awhile and it works great.
Re: 2000 Durango code P1491 diving me nuts [Re: reflections7] #158010
12/02/08 06:15 PM
12/02/08 06:15 PM
Hampton, Ga.
Green Meister
Green Meister
Hampton, Ga.
I found a $100 junkyard one. Installed it and runs like a top with no check engine light.
