Aluminum rods on the street #1578668
02/13/14 08:03 PM
02/13/14 08:03 PM
Utah
dragnduster Offline OP
Utah
I am thinking of picking up a 514 inch short block that has aluminum rods in it and I am thinking of putting it in my street/strip Dart. The Dart usually sees 100-300 street miles a year. What is everyone's thoughts of using aluminum rods on the street?
Re: Aluminum rods on the street [Re: dragnduster] #1578669
02/13/14 08:06 PM
02/13/14 08:06 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Bill Miller himself told me use them on the street, no problem. He said that's where to recycle race rods that have to many passes.
Doug
Re: Aluminum rods on the street [Re: dragnduster] #1578670
02/13/14 08:07 PM
02/13/14 08:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
For that amount of miles and I assume a much lower
RPM, I wouldnt even give it a thought... that wont hurt them a bit
Re: Aluminum rods on the street [Re: MR_P_BODY] #1578671
02/13/14 08:10 PM
02/13/14 08:10 PM
Utah
Utah
Thanks for the replies, I think it would be fun to put in a big inch motor and trade out my 3.91 gears for some 3.23 gears.
Re: Aluminum rods on the street [Re: dragnduster] #1578672
02/13/14 08:47 PM
02/13/14 08:47 PM
Utah
Utah
Do I do anything different with an aluminum rod as far as warm up before driving it? Any other tricks to running them?
Re: Aluminum rods on the street [Re: dragnduster] #1578673
02/13/14 08:49 PM
02/13/14 08:49 PM
Do you know the history of the motor and which brand and age of the aluminum rods?
Re: Aluminum rods on the street [Re: Cab_Burge] #1578674
02/13/14 08:51 PM
02/13/14 08:51 PM
Utah
Utah
No I don't, I will look more into now that I have found it to be okay to run them on the street.
Re: Aluminum rods on the street [Re: dragnduster] #1578675
02/13/14 09:54 PM
02/13/14 09:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Warm it up before driving
Re: Aluminum rods on the street [Re: MR_P_BODY] #1578676
02/13/14 11:08 PM
02/13/14 11:08 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
Check out Bill millers web site I think he tells you to use 20-50 weight oil in a street car.
Re: Aluminum rods on the street [Re: MR_P_BODY] #1578677
02/13/14 11:40 PM
02/13/14 11:40 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
What's the purpose if warming it up before driving? Bearing clearances?
Re: Aluminum rods on the street [Re: Quicksilver440] #1578678
02/14/14 02:12 AM
02/14/14 02:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes
