Hi, I have an opportunity to buy this 402 that was put together by Indy.
Looks like a good price, I was looking around for a 408 set up when I found this
Here is what the seller has sent me
" Hey Jackson, I have a 1968 318 block,The cam specs are in the pic's.Heads are #60779,The intake is a performer RPM# 7176,Crank is Eagel 340-c5-593.Comp cam CL20-227-4.Pistons are 8-2306,I beam eagel rods,clevet bearings.Roller rockers are 1.5 that I bought from Indy along with the stroker kit. Let me know. Thanks, Craig."
I was thinking I could change pistons and use this kit in a 340 block.
Any thoughts on it?
