Page 13 of 22 1 2 11 12 13 14 15 21 22
Re: Let the Hemi swap begin [Re: feets] #1577579
01/05/15 02:09 AM
01/05/15 02:09 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Is it done yet?
The fuel system is about half done.
It is as follows:
1/2" factory style pickup (I wish I had a 3/8 again just for the time being)
7 psi Holley Mighty Mite pointed at the passengers frame rail on a 45* angle (following the directions)
Feeding into the 1.5 quart accumulator where the passengers side exhaust hanger is. (I'm really lucky this fit so well...)
The GSL 392 picks up from there and pushes into the Corvette fuel regulator/filter.
From there it runs back into the factory style 1/2" fuel lines that I've got running on the passengers rocker panel.
All the main components are in place and bolted down. I tried using regular 3/8" EFI hose from the parts store and its junk. I'm going to go back to my original plan of using the Aeroquip AQP like Wade suggested. It's more durable and less likely to kink around bends.
I'm also going to put a splice in for a fuel pressure sensor port right after the regulator to main line. If I have either pump act up, I will be able to verify there is a problem this way.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Let the Hemi swap begin [Re: AlexP] #1577580
01/05/15 04:12 AM
01/05/15 04:12 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Is that Aeroquip AQP stuff teflon lined? Hopefully it is so you don't get a fuel smell inside the car. You are still running the dead head setup?
I will be running a bypass return in mine
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Let the Hemi swap begin [Re: AlexP] #1577581
01/05/15 10:37 AM
01/05/15 10:37 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Can you setup the ECU to monitor that sensor for you? Either PSI/RPM based rev limit adjustment or at least a warning light.
After Wade's experience, you would want something in place for that..
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Let the Hemi swap begin [Re: GoodysGotaCuda] #1577582
01/05/15 12:11 PM
01/05/15 12:11 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
My experience is probably a little extreme and mostly due to the proximity to the muffler and the extended high load run conditions. But I agree on monitoring the fuel pressure.
I started monitoring / logging fuel pressure a few weeks ago. Initially I had a sensor at the end of the passenger side fuel rail. The readings were very erratic. I installed a second sensor back right up against the corvette filter/regulator. Much more stable fuel pressure reading, and staying right where it should.
Megasquirt does have a check engine light capability. I haven't used it yet. It will monitor whatever you want it to. The more important thing you need to set up is AFR control- it's a table where you designate the allowable deviation from your spec'd AFR table, qualifying event time, etc. That will keep you from hurting anything.
Megasquirt has like 20 ports you can set up for monitoring 0-5v sensors. So you could add a fuel temp sensor as well if you so chose.
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Let the Hemi swap begin [Re: Uhcoog1] #1577583
01/05/15 01:03 PM
01/05/15 01:03 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Temp makes more sense than another pressure sensor.
I will be taking advantage of the full range of safety nets that MS has to offer.
I'm not sure about the fuel line being teflon lined or not. I know Wade's car has never smelled like fuel any time I've been around it, so its a non issue.
My fuel system is set up to make big power. I've got 1/2" feed and return lines, but for this version of the car I dont need to run the frame mounted return. My return line will be dumping back into the tank right by the sending unit instead of going back up front for no reason. This single GSL392 will support 600 crank, so I'll be fine. If I go with my Paxton SC kit, I'll add a second GSL392 and be good.
Re: Let the Hemi swap begin [Re: AlexP] #1577584
01/16/15 01:01 PM
01/16/15 01:01 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Work work work. Now I need some time to order another round of parts. The sun finally came out after weeks of cold and rain. It's a lovely 60 degrees here today and I hope to get some more work done on the car this weekend.
I'm looking at getting a spare 6.1 block with all of the buzz about them re-releasing them.
Re: Let the Hemi swap begin [Re: AlexP] #1577585
02/04/15 02:28 AM
02/04/15 02:28 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Some parts ordering happened:
-Hurst Competition Plus Shifter for a non-console car with install kit.
-06AN AQP Hose and random fittings I forgot the first time around (I need to get rid of the parts store rubber stuff.)
-Moroso Battery Box for the trunk mount (I'll size the battery from there.)
-GPS Transponder, Bluetooth Cable, USB Cable, Tunerstudio software
I'm looking to put finish wiring the fuel system and battery, put pressure to the fuel system and fire the car this month before I go out of town for work for a few weeks.
March and April are show season and I'd like to drive the car a few hundred miles to a show in April.
Re: Let the Hemi swap begin [Re: AlexP] #1577586
02/05/15 03:27 PM
02/05/15 03:27 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I also picked up this for my voltage regulator:
http://store.alternatorparts.com/hd-external-voltage-regulator-conversion-kit.aspx
http://www.youtube.com/watch?v=JitAfEopoM4
My ECU has alternator control, but this will help in the unlikely event that I have an alternator fault...I'd rather not kill the MS3 box.
Re: Let the Hemi swap begin [Re: AlexP] #1577587
02/05/15 03:47 PM
02/05/15 03:47 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Yeah I wonder about the alternator control, I hope it works. I will leave a spot under the dash for a regulator too just in case.
Mopar to the bone!!!
Re: Let the Hemi swap begin [Re: 72Swinger] #1577588
02/05/15 04:01 PM
02/05/15 04:01 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I dont get a warm and fuzzy feeling about it just yet. I like this external unit a lot more, and the harness it comes with looks sturdy.
Re: Let the Hemi swap begin [Re: AlexP] #1577589
02/05/15 04:10 PM
02/05/15 04:10 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I've seen that kit as well just found it to be over priced.
Very interested in your results though as I will probably use the same parts
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Let the Hemi swap begin [Re: RylisPro] #1577590
02/05/15 04:34 PM
02/05/15 04:34 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
If you talk to the guy it wont seem overpriced. The voltage regulator is of higher quality than the off the shelf units, so that right there is enough of a justification.
Re: Let the Hemi swap begin [Re: AlexP] #1577591
02/05/15 04:40 PM
02/05/15 04:40 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Let the Hemi swap begin [Re: RylisPro] #1577592
02/05/15 04:56 PM
02/05/15 04:56 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
http://www.aspwholesale.com/index.php?_a=product&product_id=2094
Vs.
http://store.alternatorparts.com/partnoc8313.aspx
I bought from here:
~$25 shipped
it is the C8313 just the same as what Alex bought. Hasn't failed me yet after a few thousand miles and a few track weekends. Previously I went through 3 or 4 of the autozone 'lifetime warranty' voltage regulators. This regulator will handle 7+ amps of field draw, which is about what the hemi alternator will draw at full power (according to an alternator specialist I spoke with).
Re: Let the Hemi swap begin [Re: Uhcoog1] #1577593
02/05/15 05:15 PM
02/05/15 05:15 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
The guy that I bought from said that this will handle 10 amps of field.
I'm getting lazy right before I finish the car. The more that is plug and play with this build, the better. I like having a harness laid out for me.
Re: Let the Hemi swap begin [Re: AlexP] #1577594
02/05/15 05:28 PM
02/05/15 05:28 PM
Central IL
Trojmn Offline
Trojmn  Offline
Central IL
This is pretty handy>> "If you want to adjust the voltage regulator you use the screw on the back"
I'm pretty sure AGM batteries don't appreciate a constant 14.5V. A Chrysler computer typically wants to command something like ~13.6V but still needs to know what the voltage is to skew sensor's reference voltage appropriately. MS3 may not care so much, but at least this regulator allows adjustment and a AGM battery will last longer.
Re: Let the Hemi swap begin [Re: Trojmn] #1577595
02/05/15 05:57 PM
02/05/15 05:57 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
[quote}If you talk to the guy it wont seem overpriced. The voltage regulator is of higher quality than the off the shelf units, so that right there is enough of a justification.
You should see what the AGM batteries do at 18+ volts and 160 amps. I've never seen a battery smoke until one of the autozone voltage regulators failed causing the 18+v/160a condition. ha
Re: Let the Hemi swap begin [Re: Uhcoog1] #1577596
02/16/15 02:11 AM
02/16/15 02:11 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Mild update and very uneventful.
Picked the mounting spot for the moroso battery box. Took it with me to the auto parts store and was in such a rush that I didn't even think to get it out of the truck and see what batteries will fit. Fail.
Picked up a 2000 camaro ls1 ps pump. With reservior from autozone. I need a few bits and pieces to get it on with Emils bracket.
Completely started over on my fuel system. I had it all messed up and some overdone loops to make it fit. I've keep all the same components but re positioned them in better places. Looks cleaner and safer.
I started installing my shifter but I'm missing the 1/2 lever. I'll call hurst tomorrow and get the right one in. I'm very happy that I decided to go all new on the shifter and linkages.
I stripped the weatherstripping off of the trunk and put new replacement from Classic industries in. Such a huge improvement and it may fix my trunk leak.
Things left to do before I can fire:
Run the new battery cable to the trunk and finish the install.
Run wiring to fuel pumps.
Permanently mount ms3 box (no big deal, just didn't feel comfortable with it sitting in the car)
Fill trans with fluid
Get driveshaft balanced and put new joints in.
I've got sway bars, wheels, tires, big brake kit and a dash rebuild looming, but I won't stray from it running first.
Re: Let the Hemi swap begin [Re: AlexP] #1577597
02/16/15 02:37 AM
02/16/15 02:37 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Nice!
2020 RAM 1500
Re: Let the Hemi swap begin [Re: GoodysGotaCuda] #1577598
02/16/15 02:54 AM
02/16/15 02:54 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Alex keep plugging til its making noise. I'm gonna get mine running before fenders are on or the the wiring for lights is done. After they pop, it brings a calm to the process and you relax and everything else is easy.
