Page 11 of 22 1 2 9 10 11 12 13 21 22
Re: Let the Hemi swap begin [Re: 68KillerBee] #1577539
11/19/14 11:18 AM
11/19/14 11:18 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
This thread is very inspiring. Too bad I'm in the middle of a stroker build.
Just have a stock 18 spline transmission going in? I searched the thread, but didn't see that info.
I'm going to run a 23 spline for now. I don't feel that I will break the trans, because I purposely put a basic clutch in. It's going to be a hard 1000 miles to break the car in...no WOT, downshifts...man.
T56 or a Passon 5 speed will be a hard choice later.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Let the Hemi swap begin [Re: Moparmal] #1577540
11/19/14 01:16 PM
11/19/14 01:16 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
How come mine is a completely different animal??
Easy.
You used the wrong color of Play Doh when checking valve clearance.
- Stu Harmon
Re: Let the Hemi swap begin [Re: feets] #1577541
11/19/14 11:25 PM
11/19/14 11:25 PM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
Ill have you know its " modelling clay"......
Re: Let the Hemi swap begin [Re: Moparmal] #1577542
11/19/14 11:28 PM
11/19/14 11:28 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
What was your measured clearance? With what springs, pushrods, gasket, and lifters?
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Let the Hemi swap begin [Re: Moparmal] #1577543
11/20/14 12:37 AM
11/20/14 12:37 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
There's your problem. Do it right next time.
- Stu Harmon
Re: Let the Hemi swap begin [Re: Uhcoog1] #1577544
11/20/14 07:13 AM
11/20/14 07:13 AM
Moparmal Offline
Moparmal  Offline
Factory rockers, push rods and valve springs.
Lifters supplied by Sharandon that my mate converted to a solid by removing the plunger..gauging the plunger depth and inserting a shim instead of the spring.
We re-used the compressed head gasket that was taken from the un-started motor.
Cam was ground on a 110 lsa at Stu from Inertias suggestion - still not sure if that was a smart thing to do....
Cam was degreed and went in at 114. You know the rest on that score.....
P-V was .068th on the intake side, .124th exhaust.
Il say it again - the p-v I can live with....but the ICL these install at is not friendly to carb induction.
Id be VERY interested in hearing what Alex cam actually installed at..... Or did you degree it already with a multi keyway?
Re: Let the Hemi swap begin [Re: Moparmal] #1577545
11/24/14 12:59 AM
11/24/14 12:59 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I did some odds and ends today. I got my z-bar properly installed, linkage spring in place for clutch fork, and I need to get the linkage to the pedals back in with the right boot. I also installed the catch can by Billet Tech (a must for any hemi, or a Pan evac)
I fixed my torsion bars kinda, but the CAP Tubular UCA's need to go. Too much adjustment for my tastes. Factory Uppers with the Problem solver bushings will keep me going for a while. I need to play with ride height once the new wheel and tire combo is in. It seems too low, but I've driven stupid low cars daily...doesn't scare me but I don't want to tear the headers apart.
I also tried fitting my cooling system, but the C-body radiator is too huge for the hoses I've got. I tried the 1.75 to 1.5" adapter for the bottom hose, but I'm going to have to shorten all the hoses or notch the K-frame for it to clear. I dont want to do the second one, so I may end up with this radiator. The curve of the bottom hose is too close to the k-frame with the silicone adapter.
THIS ON EBAY.
Some pics from today...
Ride height (First time on ground since the hemi install) It's stupid low.
Lower radiator hose issue. It sits too far back due to the radiator being both thick and offset too far back. (I knew this coming into it, when the car was a BB I had to buy the shorter Jaguar fan clutch)
Clutch linkage and Z-bar fit. A blessing with the TTI headers, I really was expecting to buy a Hydraulic set up.
And a little suprise. My good buddy Uhcoog1 came by to do some "data logging" today and gave some of my friends rides with his new built to the tee 6.1 based 392. The car rips and it's only 60% tuned. It's very safe on AFR, so he showed some folks what it can do.
http://vid1113.photobucket.com/albums/k508/alex440/5410BFB8-A02F-41AC-B77A-43DF83A102A2.mp4
I've never felt confident in an old mopar at speed or around a corner until I drove his car. It's a work of art and completely built in his garage. He deserves massive props! More people need to build their own cars.
Re: Let the Hemi swap begin [Re: AlexP] #1577546
11/24/14 03:15 AM
11/24/14 03:15 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Give those bars 2 full turns.
Mopar to the bone!!!
Re: Let the Hemi swap begin [Re: AlexP] #1577547
11/24/14 04:35 AM
11/24/14 04:35 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Very nice!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Let the Hemi swap begin [Re: AlexP] #1577548
11/24/14 05:14 AM
11/24/14 05:14 AM
Moparmal Offline
Moparmal  Offline
Alex - that's the Champion radiator I used. CC1643
I've been very happy with it - but one word of caution -
The inlet and outlet diameters are the reverse of the 6.1 G3 Hemi inlet outlet. (Not sure about the 5.7)
So you end up with 1.75 going to 1.5, and 1.5 going to 1.75
I ended up using two universal Gates reduction hoses 1.75 - 1.5 and another reversed the other way.
http://moparskunkwerks.wordpress.com/2013/03/25/traps-for-the-rat/
Re: Let the Hemi swap begin [Re: Moparmal] #1577549
11/24/14 05:19 AM
11/24/14 05:19 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
You might want to try calling Champion. I believe they were making a GenIII radiator that reverses the inlet/outlet. I remember seeing a thread on it not too long ago on FABO.
Re: Let the Hemi swap begin [Re: MuuMuu101] #1577550
11/24/14 05:39 AM
11/24/14 05:39 AM
Moparmal Offline
Moparmal  Offline
The CC1643 is advertised as the "B Body Gen 3 Hemi" radiator..
Not saying there isn't another model - but we've both missed it....
Re: Let the Hemi swap begin [Re: Moparmal] #1577551
11/24/14 02:33 PM
11/24/14 02:33 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I'll call them. If I can butcher this radiator for start up I will. I don't want to spend $100 getting an outlet put on for something that may leak down the road when the right radiator is $200
Re: Let the Hemi swap begin [Re: AlexP] #1577552
11/24/14 05:11 PM
11/24/14 05:11 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Thanks for the kind words, Alex! Let's get yours running so we can start tuning yours as well.
Re: Let the Hemi swap begin [Re: Moparmal] #1577553
11/24/14 05:35 PM
11/24/14 05:35 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
The factory hoses work fine.
My radiator is 1.5" upper, 1.75" lower (same as champion I believe)
Engine side is 1.75" upper, 1.625" lower
Copy and paste from my post on FABO:
Upper radiator hose for passenger side neck:
Dayco C72282 - ID of 1.44 and 1.72 (for a 2006 Dodge Charger 5.7 hemi)
Gates 22940 - ID of 1.44 and 1.75
Lower radiator hose for passenger side neck:
Dayco E72225 - ID of 1.59 and 1.78 (for a 2008 Jeep Grand Cherokee SRT8 )
Gates 23036: 20.6" length, 1.63" ID, 1.75" ID
Upper radiator hose for drivers side neck:
?? - Jeep SRT8 upper radiator hose - appears to be 1.5" radiator neck, 1.75" water pump neck
Goodyear 62968
Lower radiator hose for drivers side neck:
Dayco E72281 - 1.44 & 1.66 ID (I measured this one in the store- the water pump side was ~1.5" I think, and the radiator side was smaller) - this is for a 5.7 dodge charger
*I think a SRT8 lower radiator hose would have a larger hose ID for the radiator side. I don't know, as autozone and Rock Auto both do not have hoses for the SRT8 cars, period. Looks like you'll have to go to the dealer.]
Re: Let the Hemi swap begin [Re: Uhcoog1] #1577554
11/24/14 07:23 PM
11/24/14 07:23 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
You know me. Slow and steady gets the car done sometime before the end of the next century.
Re: Let the Hemi swap begin [Re: Uhcoog1] #1577555
11/24/14 07:45 PM
11/24/14 07:45 PM
Moparmal Offline
Moparmal  Offline
UHCoog - So the factory hoses are tapered as well?
Wonder why they did that?
And here was me thinking they'd got the radiator all wrong
I better edit my blog as well...... ops:
Ah well....makes it easy for you guys - unfo we couldn't get the factory hoses over here without paying stupid high dealer costs.... So alls well I guess..
Re: Let the Hemi swap begin [Re: Moparmal] #1577556
11/24/14 11:40 PM
11/24/14 11:40 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Yeah- I ordered an adapter as well thinking there would be sizing issues- well that adapter is still on the shelf!
Re: Let the Hemi swap begin [Re: Uhcoog1] #1577557
11/26/14 11:24 PM
11/26/14 11:24 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I took off work today due to the obscene amount of hours I've worked this month (no complaints...just tired) and I got a bunch done on the car!
I mounted the EFI box on the area directly beneath my factory AC box. It's really a perfect fit and the box is very well sized. I see the point in his sliding bracket design. I really like it.
I can have the ECU in and out in under a few minutes.
I tried my best to hide the wires. This is easier by far in a B-body than wades A-body...I really didn't want to have to run the 2" holesaw thorough my firewall. I'm going to further protect the wires in the fender well. I was initially worried about a blow out of a tire killing the wiring harness, but if that happens I've already got a ton of problems.
The harness laid out well in the engine bay. Not a problem worth mentioning. The connectors are OEM quality and the routing is very logical. I know agree with Emil's idea of resheathing the harness, but I could easily remove the whole harness at a later date.
I'm going to be able to use my C-body 440 Police radiator without issue. I simply trimmed down the 1.5" to 1.75" silicone adapter and cut a 1.5" U bend down in the curve and made it work for my lower hose. It clears the K-frame by about an inch and stays away from all critical items. I wan't to go over all the ends with T-bolt clamps. I hate worm gear clamps.
I also did a test fit of the 18x9" mustang wheels I picked up for $69 each. They'll need the hub opened up a bit, but the offset looks good and they'll clear the tie rod end.
Now I need something bigger than 11.75" brakes.
On a semi related note...Can someone tell me what goes in this hole? I can't remember for the life of me!
Re: Let the Hemi swap begin [Re: AlexP] #1577558
11/27/14 12:34 AM
11/27/14 12:34 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Awesome!
Aren't B&E body engine bays/ K-frames the same dimension wise? That looks like way more room compared to a 340.
Gives me ideas of how to route things
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
