easy way to tell 727 big from small?? #15753
07/18/05 02:46 PM
07/18/05 02:46 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
i got a 727 in a deal with a car the 727 was inside the car has no converter what is the most easy way to tell if it for a small block or big block?
thanks ralph
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: easy way to tell 727 big from small?? [Re: toplescuda] #15754
07/18/05 02:52 PM
07/18/05 02:52 PM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
The small block has a bolt hole in the top center of the bell housinr and the big block doesn't
Re: easy way to tell 727 big from small?? [Re: Leadfoot] #15755
07/18/05 03:09 PM
07/18/05 03:09 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
cool deal thanks for the info now i got to go look lol
ralph
1971 charger
Re: easy way to tell 727 big from small?? [Re: Leadfoot] #15756
07/18/05 03:30 PM
07/18/05 03:30 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Neither bellhousing has a bolt at the top center.
The easiest way to tell them apart is the bottom row of 4 bolt holes in the bellhousing, the big block has 4 small holes while the small block has two small and two large holes.
Re: easy way to tell 727 big from small?? [Re: John_Kunkel] #15757
07/18/05 05:49 PM
07/18/05 05:49 PM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
My mistake! But now I'm confused.I went and checked a block and there is a hole in the top center. I checked my trans and there is no hole. What gives?
Re: easy way to tell 727 big from small?? [Re: Leadfoot] #15758
07/18/05 06:00 PM
07/18/05 06:00 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
My 4-spd bell housing has the top center hole. No I can't take a picture, it's in the car and can't get a camera back down there. Maybe if you beg enough I could pull the car out and try.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: easy way to tell 727 big from small?? [Re: amxautox] #15759
07/18/05 06:18 PM
07/18/05 06:18 PM
Palm Coast, FL (near Daytona B...
Blown_Hemi Offline
Blown_Hemi  Offline
My cast iron small block truck bell has a hole at the top also. John is correct about the 727 housings. That is how I usually tell the difference.
Ask me my opinion of Frank Mitchell....... A Mopar crook!
Re: easy way to tell 727 big from small?? [Re: Blown_Hemi] #15760
07/18/05 06:20 PM
07/18/05 06:20 PM
another easy way to tell- small block starters are below the crank center line , big blocks are inline with the crank centerline. horizontally of course...
Re: easy way to tell 727 big from small?? [Re: Blown_Hemi] #15761
07/18/05 08:14 PM
07/18/05 08:14 PM
Colorado
Leadfoot Offline
Leadfoot  Offline
Colorado
I guess I just put a bolt wherever there was a hole and never paid much attention.
Re: easy way to tell 727 big from small?? [Re: Leadfoot] #15762
07/18/05 08:50 PM
07/18/05 08:50 PM
I also use starter position to tell the difference. Use the kickdown linkage boss as a refrence point. If I remember right, its above the top starter bolt on the SB and below the top starter bolt on a BB. Its hard to explain but its an easy way to tell them apart.
Re: easy way to tell 727 big from small?? #15763
07/18/05 09:15 PM
07/18/05 09:15 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
wellm mine dont have a hole in the top so here is what i did i measures the center between the 2 top bolts on a my big block (in car) it is 8 inches(or close enuff) from center of bolt hole to center of bolt hole and the small block is 6 3/4 some tranny have a inch and a half or so on top but those are for motor homes and vans to check the timing through
ralph
1971 charger
Re: easy way to tell 727 big from small?? [Re: John_Kunkel] #15764
07/18/05 10:06 PM
07/18/05 10:06 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
see the tranny on the left? look just under the starter. See the curve? That's the easiest way for me to tell it's a small block. By the curve. And the 2 brace mounts for the block at the bottom of the dust cover helps too.
Re: easy way to tell 727 big from small?? #15765
07/18/05 10:40 PM
07/18/05 10:40 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
I use this method
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: easy way to tell 727 big from small?? [Re: AZ_A12_BEE] #15766
07/18/05 11:21 PM
07/18/05 11:21 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I always used the square hole in the top for reference. The small block has about 2" seperating the bolt hole and the square hole while the big block has it about an inch.
JB Rhinehart, Realist
A-Body's RULE!
Re: easy way to tell 727 big from small?? [Re: Rhinodart] #15767
07/18/05 11:25 PM
07/18/05 11:25 PM
amxautox Offline
amxautox  Offline
What square hole?
edit; that one sorta next to the bolt hole? [looking at the picture posted above] Never seen or at least paid attention to it before.
Tom
author unknown
Re: easy way to tell 727 big from small?? [Re: AZ_A12_BEE] #15768
07/18/05 11:59 PM
07/18/05 11:59 PM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
I use this method
Ditto here. Quick and dirty.
Use the input shaft centerline as a reference and imagine looking at a clock...
BB starter location will be dead on at 3:00 and the SB starter location will be closer to 4:00.
Re: easy way to tell 727 big from small?? [Re: Rhinodart] #15769
07/19/05 11:09 AM
07/19/05 11:09 AM
Easy way for me is if i can fit one finger between the square and round hole it's a big block, two fingers and it's a small block
Re: easy way to tell 727 big from small?? #15770
07/19/05 12:35 PM
07/19/05 12:35 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Ahh, Two Fingers Tequila, I think I remember it.....
A-Body's RULE!
Re: easy way to tell 727 big from small?? #15771
07/19/05 12:36 PM
07/19/05 12:36 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
What the heck is the square hole there for? I've always wondered about it.
Tim
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: easy way to tell 727 big from small?? [Re: 70dart360] #15772
07/19/05 01:41 PM
07/19/05 01:41 PM
amxautox Offline
amxautox  Offline
Ok, the square hole is only on the INSIDE of the bell, it can't be seen from the outside, it doesn't go all the way thru. Somebody might have mentioned that. I just went out to find these elusive holes. As I said earlier I've never even seen a square hole.
Whenever I've had a tranny off I've only looked at the seals, ect. Never figured why I'd need to look at the holes. Now I have a reason to look at the holes too.
Tom
author unknown
