Re: '70 ebody 383 AC water pump and crank pulley diameters?
[Re: smos001]
#1575365
02/07/14 01:40 PM
02/07/14 01:40 PM
RapidRobert
I dont know the OE diameters but post what you have & I'll tell you if there will be an issue with the pump speed (too low-overheating or too high-cavitation). The crank pulley MAY be 7&1/4. Are you wanting it to be OE or worried about incorrect pump speed? Holler back & we'll go from there
[Re: smos001]
#1575367
02/07/14 09:59 PM
02/07/14 09:59 PM
RapidRobert
Alright, get me the dia's when you can & does the flow cooler pump have a flat circular "anticav plate" welded on?. When was it running hot, stoplight to stoplight or on the hiway (above ~40 MPH). I'm assuming the mixture/timing is in the ballpark
[Re: smos001]
#1575368
02/07/14 10:28 PM
02/07/14 10:28 PM
Posts: 2,262 Groveland, MA
SteveS
Groveland, MA
What are you running for a thermostat?
Steve
Someday I'll have another C-body.
