big block cooling issues
#1575263
02/07/14 03:12 AM
02/07/14 03:12 AM
Posts: 2,470 Sydney,Australia
tex013
Sydney,Australia
having problems with a 440 wedge just gets hotter etc .Have replaced blocked radiator with cross flow type , no change . Waterpump , iron curved impellor fittel paddle type , no change .Thermostat or not , no change . I recall there was a guy here who plugged or reduced the size of the bypass port in the waterpump housing . Am I correct ? It does have a aluminium housing Motoris a bit of an unknown , maybe 11:1 , eddy heads . Does only have 17deg BTDC , probly a bit low but should not be that far off , may need 20
Thoughts , Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
Re: big block cooling issues
[Re: Jeremiah]
#1575265
02/07/14 03:44 AM
02/07/14 03:44 AM
tex013
Sydney,Australia
Jeremiah, the housing is my next move . timing is initial big electric fan 1050 dominator running a bit rich there is about 35degree F drop across the radiator but at tstat is 230-240 thanks
Tex
[Re: Gabby63]
#1575268
02/07/14 05:07 AM
02/07/14 05:07 AM
Posts: 5,166 CT
GTX MATT
CT
That initial timing is likely sufficient, but you could try more it wont hurt. It sounds like a more radical build so it may even like it. If you've got vacuum advance you can just hook it to manifold vacuum to test it easier.
[Re: tex013]
#1575269
02/07/14 10:44 AM
02/07/14 10:44 AM
Posts: 13,386 Marion, South Carolina [><]
an8sec70cuda
Tap the bypass hole in the housing underneath the thermostat w/ an NPT tap and install a plug...then drill a 1/8" hole through the plug. It's been so long since I did it I can't remember if it was 1/4 or 3/8 NPT.
This helped dropped the temp 5-10 degrees if I recall correctly.
[Re: tex013]
#1575270
02/07/14 02:39 PM
02/07/14 02:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
How long of time are you talking here... from a cold engine up to 240... if its a short time I would think its not flowing water ![](/ubbthreads/images/graemlins/wave.gif)
[Re: tex013]
#1575271
02/07/14 05:40 PM
02/07/14 05:40 PM
Posts: 7,506 Az
Crizila
Az
Thoughts , Tex
If good at cruise, but over heats at idle / not moving enough air over the rad. Other way, not enough rad or coolant flow problem. Most filled blocks don't have a coolant problem. They got higher oil temps - unless the block is 100% filled.
Fastest 300
[Re: tex013]
#1575272
02/07/14 05:46 PM
02/07/14 05:46 PM
Thumperdart
State of confusion
having problems with a 440 wedge just gets hotter etc .Have replaced blocked radiator with cross flow type , no change . Waterpump , iron curved impellor fittel paddle type , no change .Thermostat or not , no change . I recall there was a guy here who plugged or reduced the size of the bypass port in the waterpump housing . Am I correct ? It does have a aluminium housing Motoris a bit of an unknown , maybe 11:1 , eddy heads . Does only have 17deg BTDC , probly a bit low but should not be that far off , may need 20 Thoughts , Tex
Which fan are you runnin............
[Re: rickraw]
#1575274
02/09/14 06:49 PM
02/09/14 06:49 PM
tex013
Sydney,Australia
guys, it just gets HOT . you drive around the block at work it will go 230/240 the $64 question is I hope there is no filler . thanks for coming on with the housing plug - didn't think I dreamed that. Monday morning now - back into it
Tex
[Re: Jeremiah]
#1575275
02/09/14 06:54 PM
02/09/14 06:54 PM
RapidRobert
a) Have you checked the water pump housing for casting flaws blocking flow?
X2. EDIT I'm assuming the gauge is accurate but if it IS that hot I'm sure there is no doubt about it. For it to be getting that hot that fast I'd look at. Adv weight frozen or partly stuck (not likely). restriction in alum housing (very likely in early 'source ones). combustion leak into cooling system from cracked block or head or head gasket issue (does happen). No experience with hard blok
[Re: tex013]
#1575276
02/09/14 10:11 PM
02/09/14 10:11 PM
Posts: 15,498 Omaha Ne
TJP
Omaha Ne
Pull the cap and see if it's moving coolant, years ago had a big block that constantly overheated, Pulled the water pump and the impeller was laying in the housing, HMM wonder why it was getting hot. Start with the basics and collect data, analyze and report back. if it's getting that hot after a drive around the block the problem should be readily apparent, IE: stuck thermostat, plugged radiator, collapsing intake hose, plugged radiator hose (think shop rag, incorrect fan, incorrect pulley ratios, extremely lean etc. Collect the data, keep it simple and report back ![](/ubbthreads/images/graemlins/beer.gif)
[Re: tex013]
#1575277
02/09/14 10:30 PM
02/09/14 10:30 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Are your pulleys correct? I had some cooling problems of my own for a while until I put the factory pulleys on and a proper clutch fan. ![](/ubbthreads/images/graemlins/Twocents.gif) I wasn't moving the water fast enough through the cooling system with a "drag race" type cooling system.My car was going up to 230 with no signs of cooling down until I put a stock system on it and all was well ![](/ubbthreads/images/graemlins/thumbs.gif) Gus ![](/ubbthreads/images/graemlins/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#1575278
02/09/14 11:23 PM
02/09/14 11:23 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
What brand of water pump housing do you have? I hear the 440source housing have small passages and are very restrictive..
I am truckless..
[Re: bonefish]
#1575281
02/10/14 12:16 PM
02/10/14 12:16 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
Pull the thermostat and fill block from there may be a vapour lock? ![](/ubbthreads/images/graemlins/shruggy.gif) Fan blades on right way around? don't laugh I've seen it! Check the timing mark is right on the balancer (use a piston stop) and the timing to 36 total no vacuum advance hooked up at this point. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Dodgem]
#1575282
02/10/14 06:54 PM
02/10/14 06:54 PM
tex013
Sydney,Australia
Hi, cooling fan is 16" electric blowing the correct way , pull type. no thermostat . fitted factory iron housing , had aluminium with way smaller intake ports . restricted bypass in housing . raised rear of bonnet to release air better , no gain though after driving and with motor idling 225temp opened bonnet and temp dropped to 205 . tried 2 waterpumps , 1 had curved fins - 1 had pressed metal paddles . pulleys appear stock steel , 6 3/4" crank similar size on pump . I do have a slightly smaller pump pulley , maybe 1/4" . when you pull the cap on rad you can see water flowing I can open up the hole under the hemi style scoop if need be . I can try a 7 blade fixed fan though I have no shroud to suit . I will check timing though it does have TCI rattler thanks again ,
Tex
