Heater problem on 2003 Ram hemi #1575242
02/07/14 02:17 AM
02/07/14 02:17 AM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
Hey people the heater on my 2003 Hemi Ram 4 x 4 truck just stopped giving
out very hot air today. It has always been able to blow very hot but today
for some reason even at full blast and full on heat all I get is some
slightly warm air flow.
Now If you turn the heater to off and wait a few minutes and restart the
heater it will come on good and hot for few seconds and then go back to just
blowing slightly warm air.
I noted the A/C work perfectly though.
Thanks for any advice,
Stu
Re: Heater problem on 2003 Ram hemi [Re: MidPenMopar] #1575243
02/07/14 02:31 AM
02/07/14 02:31 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Seems to be going around.
https://board.moparts.org/ubbthreads/show...e=0#Post8028537
Probably a blend door busted.
This is supposed to be the cure without having to pull the dash out of the truck.
http://www.heatertreater.net/magento/index.php/dodge/ram/02-08/dodge-ram-02-08.html
Kevin
Re: Heater problem on 2003 Ram hemi [Re: MidPenMopar] #1575244
02/07/14 02:34 AM
02/07/14 02:34 AM
70sixpkrt Offline
70sixpkrt  Offline
It might be your blower motor resistor. I had the same problem in my Durango. It is located near the blower motor. The easy way to see it is to take your glove box door off and you will see wires connected to it.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Heater problem on 2003 Ram hemi [Re: 70sixpkrt] #1575245
02/07/14 02:43 AM
02/07/14 02:43 AM
Thaks Ricky, but I don't think it's the blower motor as it does blow forced air as it should but just not very hot.
Re: Heater problem on 2003 Ram hemi [Re: Twostick] #1575246
02/07/14 02:44 AM
02/07/14 02:44 AM
Kevin
Thanks Kevin, that other post seems to be exactly like my problem....
Re: Heater problem on 2003 Ram hemi [Re: MidPenMopar] #1575247
02/07/14 10:51 PM
02/07/14 10:51 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
Flush out the heater core,might be partially plugged up.
Re: Heater problem on 2003 Ram hemi [Re: MidPenMopar] #1575248
02/07/14 11:11 PM
02/07/14 11:11 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
There are some really good Ram blend door videos on YouTube. How to get an idea which one needs replaced and how to do it without removing the dash.
My 2005 Ram has a problem with the passenger side not cooling when the ac is on.. I bought the doors last year but been put'n it off.
Ebay and AMAZON is where I bought mine
Re: Heater problem on 2003 Ram hemi [Re: GarageDodge] #1575249
02/08/14 03:56 AM
02/08/14 03:56 AM
That looks to be the cheapest thing to try first.
Re: Heater problem on 2003 Ram hemi [Re: MidPenMopar] #1575250
02/08/14 10:37 AM
02/08/14 10:37 AM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
I always try the easiest&cheapiest first can"t hurt,it could be the problem.
Re: Heater problem on 2003 Ram hemi [Re: GarageDodge] #1575251
02/08/14 12:50 PM
02/08/14 12:50 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Flushing the core isn't easy either and is messy. Instead, when the engine is hot check both hoses with your hand. If one is hot and the other isn't the core is plugged. If they're both hot then the core isn't plugged.
Its unlikely the core is plugged unless you fill your rad with straight sewer water. My vote goes to the blend door.
Re: Heater problem on 2003 Ram hemi [Re: Stanton] #1575252
02/08/14 01:11 PM
02/08/14 01:11 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
They do plug as the tubes are TINY and aluminum. If you have ever seen one cut open it would take less than a teaspoon of crud to block it up. DAMHIK.
His symptoms point towards a blend door issue which they are famous for.
Kevin
Re: Heater problem on 2003 Ram hemi [Re: Twostick] #1575253
02/08/14 01:18 PM
02/08/14 01:18 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
A couple years back I had this same problem on an 04 I had. I removed the blower motor from under the dash and reached my hand up inside and removed the broken blend doors through that opening. Installed the blower motor and all worked well for me. I think those doors are just for the recirculating air???
Either way it worked for me for the next couple of years and then I got an 07....
Re: Heater problem on 2003 Ram hemi [Re: max_maniac] #1575254
02/08/14 04:57 PM
02/08/14 04:57 PM
Ok, thank you all for more good ideas and where to start looking!!
Re: Heater problem on 2003 Ram hemi [Re: MidPenMopar] #1575255
02/10/14 09:43 PM
02/10/14 09:43 PM
Minnesota
peabodyracing Offline
Minnesota
Stu, sorry to tell you I had the same problem with my 2003. Tried blowing out the heater core, flushing it both ways, checked for the infamous blend door problem. After driving a 10 hr one way trip to pickup a car in December and freezing my butt off I took it into a local shop whom I trust.
He immediately said the core is plugged. Not the blend door. Sees it all the time. Has something to do with the design of the core seeming to plug up easier than most. I bit the bullet and paid to have it switched out as it's a pretty involved job. Wow what a difference.
Lead, follow or get the hell out of the way
Re: Heater problem on 2003 Ram hemi [Re: peabodyracing] #1575256
02/10/14 10:01 PM
02/10/14 10:01 PM
What kind of $$$ did it cost??
Re: Heater problem on 2003 Ram hemi [Re: MidPenMopar] #1575257
02/10/14 10:27 PM
02/10/14 10:27 PM
PORT ALBERNI , BC., CANADA
superwrench Offline
superwrench  Offline
It's not a "Wallet Friendly" job. About 6 1/2 hours.....at current shop rates plus parts it's a 800 buck job by the time you zap the A/C again.
But....after having seen 3 aftermarket cores leak shortly after being installed, I would highly recommend using the Mopar core...even if it's twice the price.
Re: Heater problem on 2003 Ram hemi [Re: superwrench] #1575258
02/10/14 10:48 PM
02/10/14 10:48 PM
Ok, thank you for the heads up.
Re: Heater problem on 2003 Ram hemi [Re: MidPenMopar] #1575259
02/11/14 12:06 PM
02/11/14 12:06 PM
Minnesota
Minnesota
Stu, I believe the bill was $500. They had to tear the dash pretty well apart, disconnect A/C, etc. It was an all day job. In looking at it I was really glad I didn't try it myself. Too old and stiff anymore.
Re: Heater problem on 2003 Ram hemi [Re: peabodyracing] #1575260
02/11/14 08:30 PM
02/11/14 08:30 PM
Hamilton,Ohio
P
POZEST Offline
POZEST  Offline
P
Hamilton,Ohio
Make sure you use the correct G05 coolant or equivalent if you change the core. Don't use the green stuff.......it will corrode the new aluminum core in about 5 months. DAMHIK
Re: Heater problem on 2003 Ram hemi [Re: POZEST] #1575261
02/12/14 12:23 AM
02/12/14 12:23 AM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
If you have the core changed I would recommend changing the blend&mode doors it"s just a little more labor.I do these all the time4.5 hrs start to finish,I think mitchell says almost 8 hrs.
