'70 B-Body Ignition Key Light Evans Harness Connections #1574923
02/06/14 03:57 PM
02/06/14 03:57 PM
Washington State
70_FY1_N96_BEEP Offline OP
Washington State
Howdy,
Got the service manual schematic hookups figured out. Pink(with piggyback spade connector) from relay to fuse box, Yellow with tracer(with bullet connector) from relay to the light in column, Two Yellows from relay: Each one has a different connector, one a barrel and the other a spade. Can't find where the hookup into the new Evans rally harness is supposed to be. Thanks for any help.
Re: '70 B-Body Ignition Key Light Evans Harness Connections [Re: 70_FY1_N96_BEEP] #1574924
02/06/14 05:18 PM
02/06/14 05:18 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Can't remember for sure.....I think the column light has it's wire attached directly to the light (bullet connector). The wire you described should plug right into it. Light is grounded by mounting plate. Not 100% sure though.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
