69 B Body with air grabber 2 or 3 speed wiper motor??? #157382
11/26/08 04:32 PM
11/26/08 04:32 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Was a two speed wiper motor availabe on air grabber 69 GTX or will only a three speed motor work? My car was factory two speed non air grabber but air grabber is going in and not sure if a two speed will fit??? thanks
Re: 69 B Body with air grabber 2 or 3 speed wiper motor??? [Re: frank] #157383
11/26/08 04:57 PM
11/26/08 04:57 PM
Farmland, IN
Ludington1 Offline
Happy Birthday Ludington1  Offline
Farmland, IN
Nope, the N96 required the 3-speed wiper motor.
Re: 69 B Body with air grabber 2 or 3 speed wiper motor??? [Re: Ludington1] #157384
11/26/08 05:18 PM
11/26/08 05:18 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
I ran a air grabber on mine with the 2 speed.I put a spacer between the grabber base and the carb to raise the grabber up to clear the wiper motor
Re: 69 B Body with air grabber 2 or 3 speed wiper motor??? [Re: gtx69] #157385
11/26/08 08:34 PM
11/26/08 08:34 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Any issues with hood clearence? Actually I'd like to lower the base to use a better manifold
Re: 69 B Body with air grabber 2 or 3 speed wiper motor??? [Re: frank] #157386
11/26/08 10:31 PM
11/26/08 10:31 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
not on mine but i had a six pack hood.You can buy pvc pipe and cut it and make your own spacers
