Dual carb questions - stock and aftermarket
#1572951
02/02/14 02:33 PM
02/02/14 02:33 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
How did the factory handle the PCV and other vacuum tube connections when using dual carbs on the Hemi? I am looking at using the cross ram when I put a Hemi in Road Runner.I have the opportunity to use a couple of 4510 Holleys but they have complete chokes, PCV, vacuum advance ports, etc. How would one go about using carbs that were set up for single four barrel installations into dual four barrel installations? Is there a way to pull out the little nipples that the vacuum lines connect to and insert some type of lead plug?
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
Re: Dual carb questions - stock and aftermarket
[Re: RoadRunner]
#1572952
02/02/14 03:13 PM
02/02/14 03:13 PM
RapidRobert
I have a pair of 4131 AFB's on a single plane iron B intake going (slowly) on a 451. I was just going to run the PCV hose to a T then to both of the carbs. That way both carbs recieve the same amount of the PCV (vacuum leak) & hopefully that will help keep the AF ratio equal everywhere even tho it is a single plane. This is my first dual quad & it will take some skilled tuning & I want to minimize the issues as much as I can. Just a BTT for ya!
[Re: ScottSmith_Harms]
#1572955
02/02/14 05:11 PM
02/02/14 05:11 PM
RoadRunner
I'm wondering about 68 and 69 vintage.
