Page 6 of 8 1 2 3 4 5 6 7 8
Re: Drag Week 62 Valiant's Small Block is finally ready! [Re: J_BODY] #1571983
08/18/14 03:36 AM
08/18/14 03:36 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
...and now no weekly update. something is up
Re: Drag Week 62 Valiant's Small Block is finally ready! [Re: J_BODY] #1571984
08/18/14 05:24 AM
08/18/14 05:24 AM
Phoenix, AZ
MoparBilly Offline OP
Phoenix, AZ
What's up is that I am progressing at a snails pace!
I installed a new repop trunk lock(remember the lost key incident) and carefully readjusted the trunklid to eliminate the pesky problem it developed of grabbing the rear window gasket. Afterwards I checked carefully to make sure the latch lined up with the lock. Satisfied, I slammed the trunklid shut and stepped back to admire my handy work. It was at this time, I reminded myself that I had left the keys for the new repop lock in the trunk for safekeeping! Luckily the repop trunk lock was not nearly as robust as the factory original, and it only took a screw driver and three smacks with a 2lb sledge to render it useless. I may never have a trunk lock in the car again!
The wiring is finally complete. The button at the back of the shifter is the trans brake. The smaller one mounted to the side of it goes to a toggle switch that allows it to be used for the horn or the line lock. The button on the shifter itself is for the nitrous, and is wired through the accessory 2 on my switch panel, which can only be activated when the ignition is on. The dome light works, and is activated by either door switch, as installed at the factory 52 years ago. I hooked the factory dash lights into accessory 1 with my gauges, and every single bulb lit up on cue ( The two Drag Week trips previously in this car, I had the tack light and oil pressure, that was it) The dash is completely assembled, including a new repop glove box liner.
The engine still hasn't been fired in the car, this dang Race Demon carb is kicking my butt. I rebuilt it, and now I can't get the floats or needle and seats to work, every time I turn on the fuel pump, it shoots fuel out of the vents.
I wanted to swap the seats from side to side, as the passenger one has more hip room, but apparently the six bolt helicoil pattern on the bottom of plastic race seats is not universal...didn't see that coming until I had all the brackets removed.
Boone Had a hall effect switch failure in the Barnyard Viper's distributor.
Dale still hasn't replaced the alternator on the Gremlin that failed about 4 months ago.
Darren just ordered 3800$ worth of parts for the Dakota. All of which will still need to be installed when I get to Oklahoma.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Drag Week 62 Valiant's Small Block is finally ready! [Re: MoparBilly] #1571985
08/19/14 10:46 AM
08/19/14 10:46 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Looking good Billy! See you in a few weeks.
68 Barracuda Formula S 340
Re: Drag Week 62 Valiant's Small Block is finally ready! [Re: Bad340fish] #1571986
08/19/14 07:04 PM
08/19/14 07:04 PM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
Right on schedule!
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: Drag Week 62 Valiant's Small Block is finally ready! [Re: BBR] #1571987
08/19/14 11:06 PM
08/19/14 11:06 PM
Glendale Az
Darryls-Demon Offline
Glendale Az
The keys in the trunk trick never gets old.
Re: Drag Week 62 Valiant's Small Block is finally ready! [Re: Darryls-Demon] #1571988
08/23/14 04:36 PM
08/23/14 04:36 PM
Phoenix, AZ
Phoenix, AZ
2.76s out 3.55s in. Should make consistent 11.50-11.60 passes a little easier for Rachael, and possibly allow me to take a little N20 jet away from her as well.
Boone is changing the cam and lifters on the Barnyard Viper, he's starting on it today, since he was afraid we were going into "Thrash Week" with too many cars assembled and ready to go.
Re: Drag Week 62 Valiant's Small Block is finally ready! [Re: MoparBilly] #1571989
08/24/14 01:36 AM
08/24/14 01:36 AM
Mesa, Arizona
6pak2go Offline
6pak2go  Offline
Mesa, Arizona
ROFL! So which one(s) is going to be still working on in the tech line?
Robert R
Mesa, AZ
70 Challenger R/T 440-6 4-Sp Cruiser
67 Barracuda FB 540 4-Sp Strip/Street and Drag Week
Re: Drag Week 62 Valiant's Small Block is finally ready! [Re: 6pak2go] #1571990
08/25/14 08:47 PM
08/25/14 08:47 PM
Truckville, the capital of NY
85_Ram_4speed Offline
Billy, getting stingy with the updates, LOL.
I was wondering what has been happening. Glad to see in all these years of hearing your stories and getting ready that nothing has changed. Panic right until the end!
Outcast Dodge guy.
Re: Drag Week 62 Valiant's Small Block is finally ready! [Re: 85_Ram_4speed] #1571991
08/28/14 03:58 AM
08/28/14 03:58 AM
Phoenix, AZ
Phoenix, AZ
Sorry I haven't been more forthcoming, just get frustrated on occasion.
The Belvedere.
It's sitting behind the trailer, ready to load. Once I get back to Oklahoma, I'll finish wiring up the new gauges, but mechanically I feel pretty confident. After Rachael's DNF after the first day last year, I wanted to make sure this year was better.
The Valiant.
Put Darryl's 950 HP on tonight, fuel leaking out of both accelerator pumps. Did fire it up but not for very long. When my son gets home from work in the morning we'll get the hood on it, so I can load it. Would like to head out around noon tomorrow, we will see.
The brothers aren't sending me any pictures, and are being very vague with where they are. I'm fairly Confident that the Gremlin, in all it's lexan window, 5 gallon fuel cell glory, will be ready, as will the Barnyard. Darren's Dakota however...not a chance. It was back at the chassis shop today, then goes back to the paint shop for 3 days. So we will get it Tuesday, and we are supposed to put new gauges in, interior, wiring, and convert it to E-85...I promise I'll take pictures!!
Re: Drag Week 62 Valiant's Small Block is finally ready! [Re: MoparBilly] #1571992
08/28/14 09:53 AM
08/28/14 09:53 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Billy, you have been doing this long enough to know you can't trust a body shop timeline lol.
See you soon!
Re: Drag Week 62 Valiant's Small Block is finally ready! [Re: Bad340fish] #1571993
08/28/14 08:18 PM
08/28/14 08:18 PM
Phoenix, AZ
Phoenix, AZ
Heading for Oklahoma as soon as the Grandson gets home from first grade, got to tell him bye or he will be upset!
Think I've got everything loaded...
Re: Drag Week 62 Valiant's Small Block is finally ready! [Re: MoparBilly] #1571994
08/28/14 08:25 PM
08/28/14 08:25 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
Have a Great Time .
[img] [/img]
Re: Drag Week 62 Valiant's Small Block is finally ready! [Re: MoparBilly] #1571995
08/28/14 08:30 PM
08/28/14 08:30 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
See you at Thunder Valley!
Re: Drag Week 62 Valiant's Small Block is finally ready! [Re: moparpollack] #1571996
08/29/14 03:39 PM
08/29/14 03:39 PM
lancaster,california
johnnycuda Online content
johnnycuda  Online Content
Have a safe trip, and good luck on Drag Week!!,
one day I'll get to do this.
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT!
1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air,
New daily driver-2003 Ram 2500 Cummins 5.9
'69 Valiant 2-dr, sleeper!
New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: Drag Week 62 Valiant's Small Block is finally ready! [Re: MoparBilly] #1571997
09/04/14 11:28 AM
09/04/14 11:28 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
hmmm.... no updates. I'm thinking Billy's interest is waning at this point. Maybe Drag Week is been put on the "been there, done that" list. Wonder what's next for the boy..... Silver State Challenge comes to mind
Re: Drag Week 62 Valiant's Small Block is finally ready! [Re: J_BODY] #1571998
09/04/14 01:03 PM
09/04/14 01:03 PM
Glendale Az
Glendale Az
Billy's at his brothers house in Tulsa, getting both cars ready to do some testing this Friday and Saturday night.
As far as I can tell he has put about 10 miles on the new motor in the Valiant.
He sez the new motor pulls real good and spins to 6500 very fast, he is looking forward to getting it to the track.
Re: Drag Week 62 Valiant's Small Block is finally ready! [Re: Darryls-Demon] #1571999
09/04/14 01:12 PM
09/04/14 01:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Good luck guys.... have FUN.. hoping for no breakage
EDIT
We had to put another engine in a buddies car so he
could make it this year... he should make the week
but doubts he will even make the 32 field
Re: Drag Week 62 Valiant's Small Block is finally ready! [Re: MoparBilly] #1572000
09/04/14 02:34 PM
09/04/14 02:34 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I wanted to go to test and tune Friday but I will be yanking the motor to fix a pan leak. Last weekend I yanked the motor to fix the thrust bearing and went with a different brand of gasket and it is biting me. All this for a race with zero prize money LOL.
Re: Drag Week 62 Valiant's Small Block is finally ready! [Re: Bad340fish] #1572001
09/04/14 07:01 PM
09/04/14 07:01 PM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
I heard on the first trip around town it got up to 250 degrees so they were going to have to address that this week.
Re: Drag Week 62 Valiant's Small Block is finally ready! [Re: WadeMetzinger] #1572002
09/04/14 11:29 PM
09/04/14 11:29 PM
Topeka Kansas
K
ksj Online content
ksj  Online Content
K
Topeka Kansas
Forget to fill the radiator? LOL.Me bad.The " Clan" better all be there on Sunday.See you clowns then.Crack the whip Billy.
