it has begun
#1571271
01/30/14 06:32 PM
01/30/14 06:32 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
Parts are on their way next week!! Cal tracs, mono springs, stock ride height, Im in the process of narrowing my rearend currently, will be about 1 1/4" narrower on each side. Moser axles, Mark williams load side cap on the 489 case, Crush sleeve eliminator, willwood rotors, hubs, and calipers up front, still need coil overs, and LCAs and the car will hopefully be a lot more mean on U-Joints ![](/ubbthreads/images/graemlins/beer.gif)
Re: it has begun
[Re: Moparnut426]
#1571272
01/30/14 06:36 PM
01/30/14 06:36 PM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
What tire choice did you end up with?
68 Barracuda Formula S 340
Re: it has begun
[Re: Moparnut426]
#1571276
01/31/14 02:49 PM
01/31/14 02:49 PM
Triple Threat
Renton Washington
I have heard not to use certain shocks, Should I buy the Calvert shocks, or should I buy something from afco, rancho, Qa1??
Any suggestions
Rancho = Calvert, same shock, different sticker.
Afco, QA1, Strange are probably in the next tier as far as quality and adjustability goes. That of course comes at a price. Anywhere from $150-300+ per shock.
For a mostly street/strip application, the Calvert/Rancho shock is probably your best bang for the buck. I have a set on my car I'll be selling if you're interested, PM me.
Re: it has begun
[Re: justinp61]
#1571287
01/31/14 11:29 PM
01/31/14 11:29 PM
Moparnut426
with a decent 360 it ran a 13.2 at 106 with a 1.99 60 ft.
Have never ran it with the 408.
408 is an honest 480+ engine.
indy brock heads, 10.8 diamond pistons, 602" solid roller cam, 260ish @50, chuck nuytten 750, K1 crank, Childs track master rods, Harlan rockers, yadda yadda yadda...
3.91 gears and an 833
its a fun car regardless.
Re: it has begun
[Re: 6bblRoadrunner]
#1571289
02/02/14 02:32 AM
02/02/14 02:32 AM
Moparnut426
You might want to gusset the spring perches. With a stick/CalTracs and some traction you may bend them...ask me how I know!
Thanks, I plan on wrapping them, the A body housing in the car now has wrapped perches. I used 2"x1/4" strap, used a lil heat, tacked the one edge and wrapped the strap around the housing and zipped off the other end and welded solid from there.
I know they sell a special perch that's pre gusseted, but Im a cheap azz...
![](/ubbthreads/images/graemlins/thumbs.gif)
