Dipstick Tube 360
#1568541
01/25/14 04:06 PM
01/25/14 04:06 PM
Posts: 136 AZ, USA
moon
AZ, USA
i have 78 360 front sump pan. I broke the dipstick tube but I have another one out of a truck. Still have the dipstick but I need to know the length of the tube?. Can anyone tell me its correct length from the block out?
Re: Dipstick Tube 360
[Re: moon]
#1568542
01/25/14 07:12 PM
01/25/14 07:12 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
I have a 360 truck motor in the garage and a 318 pass car motor alongside it. I will measure them but I think they will be close. I know the truck dipstick is longer because it travels down a sleeve that is spot welded to the inside of the pan to reach the oil level in the back.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Polarapete]
#1568543
01/25/14 11:13 PM
01/25/14 11:13 PM
Polarapete
Graham, WA
They are not the same! I just measured them and the truck 360 dipstick tube is 9.25" from boss to end of tube and the 318 is 7" measured the same way. The 318 came out of a '74 Dart Sport and I don't know the pedigree of the truck motor. If I were you, I would get an aftermarket universal dip stick that was a least 2.25" longer than your original, then drain and re-fill your crankcase with a full charge of oil, less 1 quart. Insert the new stick in the truck tube and mark the oil level on the stick as 1 qt low. Add the last quart, remeasure and mark that level as full. Easy.
