Re: cruising rpm [Re: Kern Dog] #1567189
01/24/14 12:45 PM
01/24/14 12:45 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
Someday I hope to go the GV route or Kiesler 4 speed auto but not in the budget now, sadly.
Uhhh... GOOD luck with that Keisler thing....
Ummm does this mean their tranny is not as good as advertised? I know it is quite a bit of money but I did like the idea of the lower 1st gear to give some more ommphh to the 3.55's I have now. Oh well, I guess I will need to do some more research as to what path to go down here. I was thinking the A518 route but not wanting to butcher my tranny crossmember to squeeze it in.
Re: cruising rpm [Re: Wyle E Coyote] #1567190
01/24/14 12:50 PM
01/24/14 12:50 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I've heard from a few engine builders that the "optimum" RPM for efficiency is the spot where the HP and Torque curves cross.
I do not know where you heard that gem, but ALL engines have their tq and hp curves cross at 5250 rpm, all of them. That is the nature of the formula that derives HP from TQ at a given RPM.
As for the RPM, drove San Diego to Memphis, N50's, 4.10's, three speed stick. 70+ mph most of the way, sometimes more, others less. 3500 rpm.
Don't be the exception.
Re: cruising rpm [Re: cjskotni] #1567191
01/24/14 02:08 PM
01/24/14 02:08 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Keisler has filed for bankruptcy and is no longer in business. I don't have any personal knowledge or experience with their 4-speed auto trans, but some may be available used. You may wish to look into a Gear Vendors add on to your 727. The Gear Vendors unit does result in a shorter driveshaft and somewhat more severe driveline angles as the rear axle moves up and down, but your wheelbase is probably long enough for it not to be too big of an issue.
Re: cruising rpm [Re: 5spdcuda] #1567192
01/24/14 05:32 PM
01/24/14 05:32 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
383ci, 3.73 rear gears, 29" tires, 727 trans, tight torque converter. I run I-5 between 3200 and 3500 RPM quite often. No big deal.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: cruising rpm [Re: Supercuda] #1567193
01/24/14 07:37 PM
01/24/14 07:37 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
your maximum lo speed torque must be your cruise rpm for efficiency.
..short duration cams should be more efficient at a lower rpms than long duration cams.
Re: cruising rpm [Re: can.al] #1567194
01/25/14 01:53 PM
01/25/14 01:53 PM
jersey
Spaceman Spiff Offline
jersey
3.73's and 275/60/15 had no problem turning 3,500 to 4,000 most of the way to Carlisle.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: cruising rpm [Re: can.al] #1567195
01/25/14 02:55 PM
01/25/14 02:55 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I know that, but that is not what the poster stated. He stated cruise RPM should be where HP and TQ curves cross, that is 5250 for all engines, all cams, all whatever.
Re: cruising rpm [Re: Supercuda] #1567196
01/25/14 03:03 PM
01/25/14 03:03 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
also, would not peak torq at part throttle occur at a lower rpm? I don't set the cruise at wot!
Re: cruising rpm [Re: can.al] #1567197
01/25/14 03:26 PM
01/25/14 03:26 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
I have 3.91's with 28" tires in the Duster. 2 1/2 hour trip to Woodward netted 3,900 RPM at 70 MPH on the freeway. Guess it's all in what you can tolerate.
Re: cruising rpm [Re: can.al] #1567198
01/25/14 03:38 PM
01/25/14 03:38 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
what would you say is an acceptable rpm to cruise at for an extended trip?
..would 2800 - 3000 be pushing it on a 2 or 3 hour period?
Ran 85 M.P.H.+ in the 'Power Tour' for 100+ miles in the past...
440 in front of 3:23's...
That was an extreme...And the sweet-spot...
All things considered out there today, run the 3:23's...
Why buzz the engine???
And why limit yourself???
Re: cruising rpm [Re: dustergirl340] #1567199
01/25/14 03:44 PM
01/25/14 03:44 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Believe it or not but I had a new 340 Duster in 71 factory equipped with 3.91 and 4 speed and it got better mileage at 70 and 3900/4000 than at 55/60.
Re: cruising rpm [Re: MoparforLife] #1567200
01/25/14 03:50 PM
01/25/14 03:50 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
I've only calculated the gas mileage in the Duster once, actually on that same Woodward trip. It got 12. So...that's pretty bad.
