Anyone use a SSBC Disc brake convertion? #156577
11/25/08 06:09 PM
11/25/08 06:09 PM
Sacramento,California
JRepucci Offline OP
JRepucci  Offline OP
Stainless Steel Brakes #884-A153 to convert a 68 barracuda to front disc brakes. Any luck?
Re: Anyone use a SSBC Disc brake convertion? [Re: JRepucci] #156578
11/25/08 06:20 PM
11/25/08 06:20 PM
Sacramento, CA
Bdrainy Offline
Bdrainy  Offline
Sacramento, CA
I used there b body one on my 70 roadrunner. I went with the power brake set up and i could not get the brakes to work well. it uses a GM master cylinder and single diaprham booster.
I put in a mopar dual diaphram booster and 15/16" bore master cylinder and the brakes work great now.
THe kit installed very easily and you can use the stock 14" wheels.
Re: Anyone use a SSBC Disc brake convertion? [Re: Bdrainy] #156579
11/25/08 11:05 PM
11/25/08 11:05 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
I put in the non-power conversion on a 69 RR and was very impressed with the ease of installation and completeness of the kit. The brakes worked great and we had no M/C issues.
Re: Anyone use a SSBC Disc brake convertion? [Re: Lee446] #156580
11/26/08 12:14 AM
11/26/08 12:14 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Jason, is that the kit with the aluminum four piston calipers? It's pricey, but the quality should be there. Check with Jim Valukis. He's probably got the parts to convert to late model discs. Or are you trying to keep small bolt pattern?
Re: Anyone use a SSBC Disc brake convertion? [Re: Jim_Lusk] #156581
11/26/08 03:38 AM
11/26/08 03:38 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I showed this kit to someone else that was doing a 68 Super Stock clone as Jason is. The S/S cars had KH A-body calipers with a special one off large pattern rotor. One SSBC kit uses cast iron KH calipers and large pattern mustang rotors that have a large center register that you can see through with steel rims.
Re: Anyone use a SSBC Disc brake convertion? [Re: autoxcuda] #156582
11/26/08 02:41 PM
11/26/08 02:41 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Just my two cents, but for that kind of money, I would want a little better than just an upgraded stockish system. Why not Aerospace or Wilwood kit? I run Wilwoods, and they are very nice for the street, super light, super easy to change pads, and fantastic at stopping. The Aerospace ones look like a step up from those....
Re: Anyone use a SSBC Disc brake convertion? [Re: JRepucci] #156583
11/26/08 07:44 PM
11/26/08 07:44 PM
North of the Motor City
DartGTDan Offline
DartGTDan  Offline
Jason,
I used the SSBC kit on my '71 Dart GT. Very expensive ($830 to my door from Mancini), but very complete. It was a simple install. I was able to keep my 14" Rallye wheels with 4" bolt pattern front and rear (8 3/4" 3.23:1 SG). I'm happy and would use SSBC again.
Dan
Re: Anyone use a SSBC Disc brake convertion? [Re: DartGTDan] #156584
11/26/08 08:29 PM
11/26/08 08:29 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
I used SSBC Manual front and rear disk break kit on my 68 with no issues,I used there alum caliper and had them powder coated black.Nice stuff went togeather with no mods.
Re: Anyone use a SSBC Disc brake convertion? [Re: RATTRAP] #156585
11/26/08 09:14 PM
11/26/08 09:14 PM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
i have done two swaps on other peoples cars. one a 65 rustang and the other is a 72 chevelle. both nice kits with no major issues to work around. other than the prices i think they are ok.
