Page 3 of 3 1 2 3
Re: What tools can you not live without for your race car? [Re: MR_P_BODY] #1565725
01/21/14 05:15 AM
01/21/14 05:15 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Compressor and flow bench are used almost daily but I wouldn't want to give up the torches or welders either.
I sold my flow bench with the idea of moving up to
a better bench... I should have kept the old one TILL
I had the new one... havent replaced it yet
I bought 2 of them and wasn't totally happy with them so I took the best features of both of them and built one exactly the way I wanted it set up. I have performed over 1000 flow test since I built it.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: What tools can you not live without for your race car? [Re: pittsburghracer] #1565726
01/21/14 11:12 AM
01/21/14 11:12 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Since you built your bench what pump did you use,
how big is it and what will it flow max... I wouldnt
mind building one.. I had a little thing that I built
years ago... it just wouldnt do much
Re: What tools can you not live without for your race car? [Re: MR_P_BODY] #1565727
01/21/14 12:21 PM
01/21/14 12:21 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
You know you when you have enough tools when the race car won't fit in the shop. My friend is just about there.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: What tools can you not live without for your race car? [Re: MR_P_BODY] #1565728
01/21/14 12:38 PM
01/21/14 12:38 PM
PA.
"Little"John
"Little"John
PA.
Mike I don't want to step all over someone's post but here are a couple of pictures. I built it with 8 motor and can flow up to app 560cfm@28 inches. The plans for it cost 50 dollars and its a fun project. I have it all hooked up to my laptop and its very easy to map out airspeeds.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: What tools can you not live without for your race car? [Re: pittsburghracer] #1565729
01/21/14 03:50 PM
01/21/14 03:50 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
A WINCH. A winch on the trailer. The best thing I ever purchased. I have one on my POS 18' open trailer. I cannot believe how many people I know with fancy high dollar enclosed trailers & they do not have a winch.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: What tools can you not live without for your race car? [Re: 65 Hemi] #1565730
01/21/14 05:42 PM
01/21/14 05:42 PM
Az
Crizila Offline
Crizila  Offline
Az
I'm tired of counting on chassis shops to get small jobs done. Ideas on which tools buy to maintain race car.
I'm buying a Tig welder, tube bender, bead roller, shear metal brake, plasma cutter, metal band saw, slip roller and tube notcher. I have most of the hand tools.
Nothin personal, but the items you mentioned, although they are chassis shop tools, they are not really maintenance tools. You gotta ask yourself how often you will be using them to be able to decide if they are cost effective to buy / own. Tools like a band saw, tig welder, plasma cutter( I would opt for a mig welder and acetylene torch over the last two mentioned for versatility - if I had nothing ) might be cost effective if you can do "double duty" with them. Then again, maybe you plan on opening a chassis shop, or roll your race car on a regular basis.
Fastest 300
Re: What tools can you not live without for your race car? [Re: Crizila] #1565731
01/21/14 07:06 PM
01/21/14 07:06 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
You bring up a good point. I have a mig, torch, and plenty of hand tools. The thing for me is I have 13 cars that always need something and friends could always use a hand. You figure if I use these tools as a hobbyist they should last. So $65,000- $75,000 over hopefully the next 20-25 years really is not to bad considering how much you would pay a shop labor.
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: What tools can you not live without for your race car? [Re: MR_P_BODY] #1565732
01/21/14 09:13 PM
01/21/14 09:13 PM
Trumbull,CT.
jim sciortino Online content
jim sciortino  Online Content
Trumbull,CT.
Since my brother swings a pretty mean wrench, I'd say he's the only "tool" I couldn't do without.
Re: What tools can you not live without for your race car? [Re: jim sciortino] #1565733
01/21/14 09:28 PM
01/21/14 09:28 PM
cincinnati ohio
mcat4321 Offline
mcat4321  Offline
cincinnati ohio
electric 4 inch hand grinder/cutting wheel.
i paid $8.99 at harbor freight in 06 best tool i have...
Re: What tools can you not live without for your race car? [Re: 65 Hemi] #1565734
01/21/14 11:46 PM
01/21/14 11:46 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Racepak.
Re: What tools can you not live without for your race car? [Re: 65 Hemi] #1565735
01/22/14 12:26 AM
01/22/14 12:26 AM
Az
Crizila Offline
Crizila  Offline
Az
13 Cars??? - never mind then . Space is also a consideration.
Fastest 300
Re: What tools can you not live without for your race car? [Re: 65 Hemi] #1565736
01/22/14 12:28 AM
01/22/14 12:28 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Add me to the list of people who said a quality tire pressure gauge. I've found that running a 275/60R15 DOT radial requires knowing where the pressure is right before belting in to pull into the water.
Re: What tools can you not live without for your race car? [Re: Crizila] #1565737
01/22/14 01:33 AM
01/22/14 01:33 AM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
I have a wonderful wife! I am building a 6000' shop with a 1500' man cave/saloon. I laugh everytime she says " you can buy anything you want as long as the bills are paid, we have our retirement, and I stay home to work on the cars". She tells her friends she never has to worry about me being at the bars. I'm never done with the cars, so I don't have time to go to the bar. She has no idea that Mopar guys are hoarders!!!
Doug
MOPAR or NO CAR!!!
Re: What tools can you not live without for your race car? [Re: MR_P_BODY] #1565738
01/22/14 01:40 AM
01/22/14 01:40 AM
OHIO
THE GLASS MAN Offline
OHIO
First on the list is my floor jack and second is my priming bar to prime the oil pressure on the HEMI!!!
Re: What tools can you not live without for your race car? [Re: THE GLASS MAN] #1565739
01/22/14 09:01 AM
01/22/14 09:01 AM
Hamilton,Ohio
P
POZEST Offline
POZEST  Offline
P
Hamilton,Ohio
I use the crap out of my electric impact at home and the track.
Re: What tools can you not live without for your race car? [Re: POZEST] #1565740
01/22/14 10:47 AM
01/22/14 10:47 AM
PA.
"Little"John
"Little"John
PA.
You may laugh at this one but I have everything in my car trailer in labeled Rubbermaid plastic boxes. Tools, electrical, carb parts, cleaning supplies, and I have one box labeled "lucky box". In that box I keep a very nice supply of nuts, bolts, washers, spacers, shims, wire lumes, butt connectors, and any other odd ball part I throw in there. People laugh when they borrow something out of it but it usually saves their racing day. The only part that gets old is instead of building their own lucky box they count to much on me having it for them and then I re-buy the stuff to restock it.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: What tools can you not live without for your race car? [Re: 65 Hemi] #1565741
01/22/14 12:30 PM
01/22/14 12:30 PM
Az
Crizila Offline
Crizila  Offline
Az
I'm a pretty lucky old dude too. My wife is my pit crew and rig driver. Couldn't do it without her.
Fastest 300
Re: What tools can you not live without for your race car? [Re: Crizila] #1565742
01/22/14 12:51 PM
01/22/14 12:51 PM
San Diego CA
65 Hemi Offline OP
65 Hemi  Offline OP
San Diego CA
Yes, you are very lucky. All the cars, tools, and races don't mean a thing if cant enjoy it with family and friends!
Doug
MOPAR or NO CAR!!!
Page 3 of 3 1 2 3
