Magnum EFI Intake on LA Motor? #156216
11/24/08 09:45 PM
11/24/08 09:45 PM
san diego
JonsGottaDusta Offline OP
san diego
Hey Everyone,
Well I am looking to do a Megasquirt on my Dart and had an idea. Is it possible ( with potential machine work ) to put a Magnum EFI intake on an LA motor? I was thinking this would be much more cost effective than boring out an intake for injectors, custom fuel rails, etc. If you have any idea's/suggestions please let me know. Thanks for your time!
- Jon D.
Re: Magnum EFI Intake on LA Motor? [Re: JonsGottaDusta] #156217
11/24/08 09:49 PM
11/24/08 09:49 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
You'd have to cross drill either the heads or the intake. And you may need to weld shut the exhaust crossover passage in the heads as the Mag intake may not cover the entire opening...
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Magnum EFI Intake on LA Motor? [Re: JonsGottaDusta] #156218
11/24/08 09:51 PM
11/24/08 09:51 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
edelbrock sells an LA version of their Victor with EFI ports drilled into the intake already....
just a note...
Tony
70 AARCuda Vitamin C
Re: Magnum EFI Intake on LA Motor? [Re: JonsGottaDusta] #156219
11/24/08 10:01 PM
11/24/08 10:01 PM
Fort Worth, TX
Clair_Davis Offline
Clair_Davis  Offline
Fort Worth, TX
You can also bolt up some Magnum or Engine Quest heads and get better heads out of the deal, too.
Clair
Re: Magnum EFI Intake on LA Motor? [Re: Clair_Davis] #156220
11/25/08 01:25 AM
11/25/08 01:25 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Or if you're really worried about cost, a TBI setup would be the cheapest way to go. A TBI from a 4.3L or larger GM engine would feed a stockish 360 to about the same amount of HP as you'd be able to make with the beer barrel intake...
