Van 9.25 8lug axle width vs Truck 9.25 8lug axle width #1561337
01/10/14 06:25 AM
01/10/14 06:25 AM
Iowa
76dodgeboy Offline OP
Iowa
Need measurements backing plate to backing plate. Plan to put one in a truck and would like to know how close vans are to trucks. Wanting 9.25 for better gearing options. Thanks
Re: Van 9.25 8lug axle width vs Truck 9.25 8lug axle width [Re: 76dodgeboy] #1561338
01/10/14 03:27 PM
01/10/14 03:27 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
It's been a while, but I'm pretty sure van axles are at least a couple of inches wider than truck rears. Also the diff is usually offset to the passenger side. Or at least the Dana's are?
The 9.25 HD is really no better than a normal 9.25. The only difference are the 8 lugs and different wheel bearings. If you're lowering this truck to the weeds why run 3/4 ton stuff anyway?
Re: Van 9.25 8lug axle width vs Truck 9.25 8lug axle width [Re: 440newport] #1561339
01/10/14 09:24 PM
01/10/14 09:24 PM
Iowa
Iowa
Because I can. The bolt pattern and Wide range of gear ratios is why I want the 8lug 9.25 instead of a D60 where 3.54 is my limit. Yeah I could run a D71 but that's Only if the 9.25 can't be found.
I wonder how offset they are? Narrow the one side and make it centered?
Re: Van 9.25 8lug axle width vs Truck 9.25 8lug axle width [Re: 76dodgeboy] #1561340
01/13/14 02:24 AM
01/13/14 02:24 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
van 9.25 and truck 9.25 are not offset---i ran a van one under my 64 plymouth with late model charger wheels and only had to move the spring perches...
Re: Van 9.25 8lug axle width vs Truck 9.25 8lug axle width [Re: savoy64] #1561341
01/13/14 04:35 AM
01/13/14 04:35 AM
Iowa
Iowa
You ran an 8lug axle in your car?
