welder feedback
#156092
11/24/08 07:53 PM
11/24/08 07:53 PM
moparpollack
Lil Herman
Lil Herman
85086
I'm looking at buying a starter welder and narrowed the choices down to a Lincoln 140 or a Hobart 140. Anyone have experiences with either good or bad?
Re: welder feedback
[Re: ToddP]
#156094
11/24/08 09:11 PM
11/24/08 09:11 PM
I have owned both, and use them a lot! The Hobart will eventually fry circuit board. I have had mine fixed twice. It is a good unit..but HAVE to stay under duty cycle. The Lincoln SP is a heavier duty welder..longer duty cycle and better quality. Now I use the new Millers..best 110 welder available. You will get more hours of use and it's more user friendly. All 3 are good machines, but the Miller is the best.
Re: welder feedback
#156095
11/24/08 10:10 PM
11/24/08 10:10 PM
moparpollack
Lil Herman
Lil Herman
85086
Well I pretty much can get the Lincoln for the price of the Hobart so I will go that route. I know the Miller is best but for my use I think the Lincoln will do fine. Thanks!
Re: welder feedback
[Re: VITC_GTX]
#156097
11/25/08 01:27 AM
11/25/08 01:27 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
why spend your money twice ? get 180 at least. with the 180 you can do rollbars, cages ect. the 140 is to light
I am truckless..
Re: welder feedback
[Re: moparpollack]
#156099
11/25/08 01:32 AM
11/25/08 01:32 AM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
I have a Hobart 150 which I believe is what the 140 was B4 Miller bought Hobart. I like it. I used shieldind gas with it but it can also use flux core
Re: welder feedback
[Re: 340SHORTY]
#156101
11/25/08 12:05 PM
11/25/08 12:05 PM
Posts: 390 pacific northwest
wings471
pacific northwest
why spend your money twice ? get 180 at least. with the 180 you can do rollbars, cages ect. the 140 is to light [/quote
ABSOLUTELY. I started with a Hobart Handler 115v mig and hated it every time I used it. I have since upgraded to a Millermatic 180 with a spool gun and my only regret is that I didn't do this sooner. PLUS the new Miller has autoset which works beautifully. I can weld alum. from 18ga. to 1/4" and mild steel from 24ga. to 5/16". You get a MIG & TIG and the cost for the 180 and spool gun was $975 and it will most likely be the last machine I will ever need to buy. If you can afford the $ don't waste your time with the inferior welders.
Re: welder feedback
[Re: 340SHORTY]
#156103
11/25/08 02:25 PM
11/25/08 02:25 PM
moparpollack
Lil Herman
Lil Herman
85086
Actually it's just for light sheet metal nothing really heavy. I have an ebay coupon and can get one to the door for about $400. I understand going bigger but the budget calls for something cheap.
Re: welder feedback
[Re: Pacnorthcuda]
#156107
11/25/08 11:43 PM
11/25/08 11:43 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I have an older Hobart 120? (small 110v mig), and it works really well on 3/16" and thinner steel. I have welded 1/4" with it for some brackets, and no problem as long as the edges are beveled so you can get into the steel. I have an old stick welder for heavier stuff. Anyhow, any of the good Brand name welders (Hobart or Lincon) work well for car hobby type projects, just spend the extra money for the gas setup. The flux cored wire leaves more spatter, and I think larger in diameter than the small solid wire. Anyhow when I tried using the flux core wire it was more prone to burn through thin sheetmetal, but it is OK on exhaust tubeing and brackets.
Re: welder feedback
[Re: moparpollack]
#156109
11/26/08 02:27 AM
11/26/08 02:27 AM
Its out of scope for what you asked about, however I must add to your thread that I love my Miller 210. Perhaps a used one on CraigsList would cost the same as a new 140? A 210 would be all you ever need in a MIG for auto type welding IMHO... I do think you will get all you need for 95% of garage work with the smaller MIG you are looking at though, so not too big a deal on the upgrade to a 210 unless you can get a good used deal.
Re: welder feedback
[Re: Scott Carl]
#156110
11/26/08 06:42 AM
11/26/08 06:42 AM
Posts: 64 Airville Pa.
boomer
Airville Pa.
Is the 140 Hobart 110v or 220v? Just wanted to clarify (since we can't edit anymore ) My 150 is 220 and is perfectly capable of welding 1/4" in one pass.
Hobart 140 is a 110 volt welder.The 140 will also weld 1/4 inch if the edges of the steel are beveled.
Re: welder feedback
[Re: Danan]
#156112
11/26/08 02:13 PM
11/26/08 02:13 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Buy the biggest welder you can afford with the money you can spend. The difference between a 110v and even the 175/180 class 220v machines is huge. There's MUCH more to a welder than the material thickness it's capable of welding. The ONLY reasons IMHO to buy a 110v machine are 1) cash 2) portability 3) lack of 220v service. Service is easy to put in. Portability isn't a big deal unless you plan on dragging it to friends to weld. Cash is the biggest issue. You can find a complete 1-3 yo Miller 175/180 with tank/cart and occasionally helmet for around 450-750. Just have to look. Craigslist is a good place to start. There's a Lincoln 250 in Tulsa for $700 And the comment about it's just for this... never works out the way... You'll end up doing other projects that require more oooomph. DAMHIK!
Re: welder feedback
[Re: RobX4406]
#156113
11/26/08 07:27 PM
11/26/08 07:27 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I've had the Lincoln 3200HD and two 140s. Stinkin thieves! I really like them and never had a need for anything larger. I've easily welded everything from sheet metal to 1/4" without ever saying "I wish I had a bigger welder." The portability is a biggie. I've hauled it around to several different places (stolen from two other homes ) to use it for structural steel and building the off road buggy amongst other things. Unless you get into something really crazy, I doubt you'll out grow one of these. If you do, save your pennies as best you can and get a SECOND welder. That way you've still got one that can be used wherever you go. I've seen some guys break important stuff on their cars at the track. They needed a welder. If they had the 110V unit, they could have powered it off a generator and fixed their ride. You can do a bunch with the little $400 units. More than most people think. However, if you decide to build ocean-going container ships or multi-lane freeway bridges, something larger would be handy.
Re: welder feedback
[Re: feets]
#156114
11/26/08 07:36 PM
11/26/08 07:36 PM
Posts: 3,160 L.I. N.Y. Hemi Street
HemiGreg
even though its not the question get a Miller mig 140. they die hard and run anywhere. ive had them all and i mean in ### and the miller is the only one still going and my 10 yr old nephew said it was the easyiest to run too. yea i got a Miller Syncrowave tooo so i can compare to the best.
Re: welder feedback
[Re: moparpollack]
#156115
11/26/08 09:19 PM
11/26/08 09:19 PM
Posts: 4,204 Fort Worth, TX
Clair_Davis
Fort Worth, TX
OK, I'm going to throw this out there because I've had a good experience with mine: Clarke 180EN 220V/180A MIGI searched for several months to find a used Miller, since there's a Miller store not far from me. Not sure what was going on, but you couldn't touch a used 110V unit for less than $700 back then (6-7 yrs ago), and I really wanted a 220V for the extra flexibility. I finally got to where I NEEDED a welder for my LCA project and couldn't find the Miller I wanted, I bit the bullet and ordered the Clarke. I got it delivered in 3 or 4 days for about $560, including the cart, autodark helmet & regulator. FWIW, the cart is functional, but a PO$, and would make a good project if you have the time. I also ordered a small pile of consumables, but most TWECO-style gun parts will fit. I wired my garage with a single 220V outlet near the door, and made up a 15-20' heavy extension cord so I could reach anywhere in the garage and most anywhere under the carport. So far, I've made an engine cradle, a set of boxled LCA's, subframe connectors, torque boxes, and a number of small engine accessory brackets. The unit has worked perfectly, with the only problems I have ever seen related to me forgetting to turn the gas on (snap-crackle-pop), forgetting to turn it off (empty tank - again!), and wire so old it gets crud on it and doesn't push well. Those have all been easy fixes. Some day I hope to have time to weld more often and avoid all three situations. Is the Clarke a great welder? Probably not. It doesn't have the infinite power/feed adjustments that other higher-dollar units have, but it seems (to this rank amateur) to do the job I need it to do. I've called their tech support (in OHIO) a few times for questions about how to weld or what to do, and they've always been helpful. For me, it was - and is - a great "starter" welder, and should last me a long time given the limited amount of welding I do. Clair
