help me pick a cam....
#1560577
01/07/14 11:48 PM
01/07/14 11:48 PM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
I need help with picking a cam. Here are the specs: 1970 383 that is .030 overbore rebuilt with factory pistons and rods 10 to 1 comp factory 906 heads redone distributor recurved 780 street avenger carb car specs: 1970 roadrunner automatic trans with a little more stall 3:55 gears power brakes and air conditioning. So it needs to make some vacuum. Any suggestions? I need it to be hydraulic. I also have adjustable rockers thanks
Re: help me pick a cam....
[Re: Cuda340]
#1560581
01/08/14 01:20 AM
01/08/14 01:20 AM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
I probably will use hughes but has anyone else have good success with any others?
Hughes doesn't grind cams,call Tim @ Bullet.
[Re: cjs69mope]
#1560585
01/09/14 05:43 AM
01/09/14 05:43 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
You realize that there are no 383 10:1 factory or factory like replacement pistons available. If it is a flat top it is probably 9:1 at best.
If they are the flat top pistons with no valve reliefs, you may be limited to pretty mild cams due to valve to piston clearance?
I would use a mild cam like the Lunati Voodoo 262/268 (60302LK.) This is 220/226 @ 0.050 duration and 0.475"/0.494" lift. It uses the 3-bolt timing gear. The Comp XE262H is about the same, but uses a single bolt timing gear. It is also slightly milider. 262/270 advertised duration, 218/224 @ 0.050" duration, 0.462"/0.470" lift.
[Re: Cuda340]
#1560588
01/11/14 03:31 AM
01/11/14 03:31 AM
Posts: 4,384 Worst Weather USA
493_DART
Worst Weather USA
I started with a Scott Brown cam in my engine a few years ago..due to all the rave reviews on this site. It worked well...the following year I tried a Hughes cam that was similar in specs . I talked to Hughes on the phone and we agreed on one of their "shelf" cams, a flat tappet that should work nice with my combo. The car picked up a TENTH . Ill stick with Hughes cams thank you Mopar company that designs Mopar cams = works for me
[Re: 493_DART]
#1560589
01/11/14 04:00 AM
01/11/14 04:00 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I always picked my own cams as I felt I had pretty good knowledge of camshafts after being a tech all my life. But when I built this pump gas 493 I wanted a nice solid flat tappet cam as I drive it on the street 99% of the time and wanted one made to work well with my combo as I also knew I was going to race it capped up. So I went to Dwayne Porter as every car I see with his cams in them run great ! And I am 100% pleased. And he is a very nice guy to work with that has good fair prices. The car more then met my goal of running 10's on pump thru the pipes and I thank him very much for grinding me a good cam. He is one of the smartest guys I have ever talked to and his work shows it. If you would decide to call him anytime just let me know as I have his phone#. You cant go wrong talking to a pro about your cam as the guys who grind the cams are pro's who do that work every day. Good luck which ever cam you use. Ron
[Re: 451Mopar]
#1560590
01/11/14 05:08 AM
01/11/14 05:08 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
I run that Voodoo in my 10.1 68 383, stock carb stock intake and exh manifolds that have been port matched and "worked" 915 heads. the cam is great a lot of low end and pulls extremely hard all the way up to 5,500, i really was surprised by this cam! it gives me 17" of vacuum at about 850 900rpm in neutral "4-speed". i also have power brakes.
[Re: ademon]
#1560591
01/11/14 11:09 AM
01/11/14 11:09 AM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
That sounds like a nice combo. Do you know what it runs? How many cars you got?
