Re: I just couldn't take it any more!
[Re: dogdays]
#1560464
01/07/14 06:24 PM
01/07/14 06:24 PM
Posts: 8,087 Elk Grove, Calif.
bigblock340power
Elk Grove, Calif.
No. The water flow through the heater core is determined by the total resistance of the system, including the resistance of the valve. Hydraulically it makes little sense to have two diffeent sizes on the intake line, the very slightly smaller flow resistance of the larger hose d/s of the valve makes miniscule difference.
The reason could be way beyond your imagination, such as: 1. Pre-existing heater core with two 5/8" nipples, change is expensive and not worth it, or: 2. With two nipples the same size either hose could hook to either nipple for easier assembly, or: 3. Running change to the nipple size on the water pump, or: 4. Smaller line adds enough restriction to prevent the water pump from going into cavitation.
See what I mean?
If I had long enough time I could come up with a half dozen more reasons that would be perfectly legitimate to a designer.
R.
All valid reasons I guess. But I still wonder what Ma Mopar was thinking?
[Re: Golden-Arm]
#1560468
01/07/14 10:46 PM
01/07/14 10:46 PM
bigblock340power
Elk Grove, Calif.
probably thinking you couldn't accidentally reverse the flow, while doing an r&r on the system, by forcing you to use two different size hoses.
You couldn't accidentally reverse the flow? If you used the right size hose in the right place. I think you could, if you used the same size hose as the person before me did. Yes, they seamed to get it right, but using the same size hose, it could be messed up. I think they used the same size hose on all the ports cause it was a lot easier to do so than going back to the store and get the right hose.
[Re: 76dodgeboy]
#1560472
01/08/14 07:04 AM
01/08/14 07:04 AM
bigblock340power
Elk Grove, Calif.
Does it really matter which way it flows through the heater core?
Oh yes! The whole cosmic universe would implode!! You heard of the big bang? That guy mixed them up.
[Re: 76dodgeboy]
#1560473
01/08/14 11:07 AM
01/08/14 11:07 AM
Posts: 15,487 Florida
scratchnfotraction
on my non-a/c 68 DART it had two 1/2" lines with no valve, water flowed all the time. heater box closed the air/heat off.
over the yrs I know I reversed the flow thru the core a couple times patching up the hoses or with an engine R&R.
allways worked with plenty of heat, even during the summer.
I remeber thinking why is there no valve on it when I got it... maybe it was MIA?
