Ummm...exhaust bolt size #155903
11/24/08 02:17 PM
11/24/08 02:17 PM
Cambridge, Ontario, Canada
CUDAJAS Offline OP
CUDAJAS  Offline OP
what thread size are the exhaust bolt holes on a stock small block LA series head?
I need to order a helicoil to fix a striped hole and want to make sure I get the right size.
I am also buying new bolts and or studs, when I look them up in the Summit catalouge, the bolts are 5/16 and the studs are 3/8...what gives
Thanks,
Jas
Re: Ummm...exhaust bolt size [Re: CUDAJAS] #155904
11/24/08 02:48 PM
11/24/08 02:48 PM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
5/16-18
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
