Re: Firecore distributor won't fit?
[Re: 80fbody]
#1557496
01/01/14 10:28 PM
01/01/14 10:28 PM
Posts: 5,180 upstate western ny
sogtx
upstate western ny
the o ring is a little thicker on ricks dizzy , i just did the same thing a couple weeks ago , but i pushed harder than you .. it fits right in .. this isnt the first distributor hes sold , it should fit it should push in with a little pressure ..
[Re: PossessedDuster]
#1557497
01/01/14 10:38 PM
01/01/14 10:38 PM
RapidRobert
I'd set the two side by side & eyeball (& measure) what is different that is holding things up. It very well might be the O ring as said
#1557500
01/02/14 12:22 AM
01/02/14 12:22 AM
Posts: 232 Alberta Canada
PossessedDuster
Alberta Canada
Don't get me wrong by no way am I dissing firecore or their product.
I pulled the gear out of the engine. The new dist. will not fit into the slot in the gear fits into the block with no issues.
The slot has seen some use and abuse however the stocker will fit in with no issues. However the end of the stock distributor isn't nearly as long and has a round "stopper" with a set screw on the end of the shaft.
Should I just look for a new gear/shaft?
Also forgot to ask. The stock dist. has/had in addition to the o-ring a flat paper gasket under the base. I've not seen this in my past small block experiance. Should a new one be sourced?
#1557501
01/02/14 12:49 AM
01/02/14 12:49 AM
RapidRobert
some years of SB dizzys use the O ring & some use the flat gasket. there's no problem using both but the flat gasket must be thin or it excessively reduces the depth of the dist tang into the intergear slot. If I'm reading this right the FC lower shaft/tang is a bit too long & wont seat into the intergear slot. I'd measure exactly how much longer the FC lower shaft and or the end tang is over the stocker & depending on that amt either a thick base gasket or trimming the dist tang end may take care of this but as you know you need a certain amt of tang length to properly engage the intergear slot. do some measureing & go from there. The coupler is an add on to reduce rotational play in the intergear slot/lower shaft tang interface to lessen spark scatter. You can use it on the FC & I'm assuming they both have a 1/2" shaft but take care of the primary problem first.
#1557503
01/02/14 02:30 AM
01/02/14 02:30 AM
RapidRobert
the tangs were all the same. I'd say the FC tang is a bit out of spec & needs a slight bit of trimming/deburring so it will fit the intergear slot. It's fine to do that just deburr any sharp edges to stop future stress risers & you want a reasonable amount or more of tang depth into the intergear slot. Just compare it to the OE one. sounds like you need to deburr the tang thinner rather than shorten it. EDIT take the big O ring off to get its' (potential) interference out of the way till you get the lower tang fit taken care of
#1557506
01/02/14 07:43 PM
01/02/14 07:43 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
It's not that the tang is too long it just will not fit into the slot on the gear. It will start but no more then a mill or so.
Was there ever any difference on the gear tang sizes over the years or do I just have a "bad one"
Good to know about the flat gasket as well.
When I talk to firecore I'll ask about the coupler as well.
have the exact same problem with a 'Skip White' billet dizzy. the tang is just a tad too wide and makes for a VERY tight fit. had the luxury of having an extra oil pump gear/shaft and and confirmed it. i ended up not using it as it had no vac advance and i didn't like the response. at $50 i wasn't gonna sweat it and put it away for maybe a future built. good looking unit though. anyway, just file the tag a little bit at a time and you'll be ok.
[Re: mikemee1331]
#1557507
01/03/14 12:44 AM
01/03/14 12:44 AM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
That would be the first Firecore distributor I have ever seen with fit issue.I've personally installed about a dozen of these distributors and they all fit tight but as stated already it was the O-ring tight. Could there possibly be an issue with the drive gear? Someone may have filed your factory distributor shaft to fit the drive in the block Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
#1557509
01/04/14 09:55 PM
01/04/14 09:55 PM
fourgearsavoy
Rittman Ohio
Cool Glad it all worked out you will love the Firecore50 ignition system. Gus
#1557511
01/04/14 10:25 PM
01/04/14 10:25 PM
mikemee1331
bethlehem pa
Just running a stock style coil. For a street cruiser is there much benefit to swap the the capacative discharge coil they sell?
what ECU?
#1557513
01/05/14 12:20 AM
01/05/14 12:20 AM
fourgearsavoy
Rittman Ohio
You shouldn't use that coil with an orange box.I would recommend a better ignition like a revnator or an older MSD unit. If you decide to stay with the orange box go with the standard MSD Blaster coil. Gus
