How to remove heater box and dash #155618
11/23/08 11:08 PM
11/23/08 11:08 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I need to remove my heater box and entire dash from my '71 Demon to paint it. Steering column is already out.
How do I do it?
Re: How to remove heater box and dash [Re: VITC_GTX] #155619
11/23/08 11:13 PM
11/23/08 11:13 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Pull the windshield out and then you will find a row of screws across the top of the dash frame hidden under the rubber window gasket. The other two dash bolts are behind the kick panels.
Make sure all the heater hoses and wiring is disconnected before pulling the dash frame out.
You can pull the heater box out by removing the bolts around the outside of the blower motor in the engine compartment along with a couple other bolts on the firewall.
Probably need to disconnect the parking brake handle from the bottom of the dash frame IIRC.
Re: How to remove heater box and dash [Re: Neil] #155620
11/23/08 11:59 PM
11/23/08 11:59 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Thanks for the information. Hopefully things go well...
