Page 3 of 3 1 2 3
Re: progress on my 42 dodge truck. [Re: fstfish66] #1555360
06/29/14 12:23 PM
06/29/14 12:23 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
looks great!! the headers might be summits block hugger headers. I have a set on my Desoto, they fit great and look good I bought them a few years ago from summit for $225 ceramic coated. I did have to file out the end holes to fit the studs on the heads, not a big deal though.
Re: progress on my 42 dodge truck. [Re: 65rbdodge] #1555361
06/29/14 09:09 PM
06/29/14 09:09 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Flex fans are junk. Throw it in the garbage!
Re: progress on my 42 dodge truck. [Re: GY3] #1555362
07/08/14 09:30 PM
07/08/14 09:30 PM
Lon207 Offline
Lon207  Offline
Again, nice ride.
What master cylinder and brake pedal/booster set up did you use? I was going to mount one on the frame on my 47, but it is looking like space will not allow that option. thanks
Re: progress on my 42 dodge truck. [Re: Lon207] #1555363
07/08/14 10:43 PM
07/08/14 10:43 PM
Shelby, Ohio
2
2abodymcodes Offline OP
Shelby, Ohio
the pedal assembly,brackets, booster , and master cylinder are all off a 69 roadrunner i parted out.
Re: progress on my 42 dodge truck. [Re: fstfish66] #1555364
07/09/14 05:19 AM
07/09/14 05:19 AM
Pa. bucks county
cuhemida Offline
cuhemida  Offline
Pa. bucks county
I am running that 318 poly raised water pump on my 1940 plymouth the motor sits low just like yours with this poly timing cover it moves the water pump up to just about center of the Rad. I am running right at 180 temp even when sitting still on a hot day it doesn't get over about 195 I also put an electric pusher Fan on just incase it would need a little help
Page 3 of 3 1 2 3
