head ID small block? #155403
11/23/08 06:26 PM
11/23/08 06:26 PM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
casting# 3418915B [J], what do i have? valve size?
Re: head ID small block? [Re: Lew] #155404
11/23/08 06:46 PM
11/23/08 06:46 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
could be 2.02 or 1.88
Re: head ID small block? [Re: RobX4406] #155405
11/23/08 06:49 PM
11/23/08 06:49 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Most likely 1.88. Not a big deal. The 2.02 is no advantage until you use the upper RPM range and the 1.88 may give better low end.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: head ID small block? [Re: MoparforLife] #155406
11/23/08 08:49 PM
11/23/08 08:49 PM
Coolville, Ohio
Lew Offline OP
Lew  Offline OP
Coolville, Ohio
thanks for replys 1.88s is ok, for now its a streeter, wont see over 5500 at the most with blue moon track time, getting ready to try out the new hughs whiplash cam, its an idle to 5300 cam so 1.88s would work fine im sure.
