Hasn't anyone had a problem using the upper hole in the spring under frame kit?
More info on my issues
I installed the blocks block to lower the rear end. I had forgotten that the spring clearance was the reason why I had them in the bottom hole. I have it mini tubbed and I am tired of the tires rubbing when I turn or hit a more than little bump. This was not an issue when I mostly raced it. For more info - I have narrowed the rear end 2". I have tried wheel spacers and it only changes the rub from in to outside.
