Re: Gator Grain Tops?
[Re: RJS]
#1553343
12/28/13 03:33 PM
12/28/13 03:33 PM
Posts: 18,157 Mass
DAYCLONA
Mass
A buddy of mine has a 70 440+6 Auto Cuda FC7 optioned with Gator Top. When the car was redone 20+ years ago the top wasn't put back on, last we spoke (5years ago) he was trying to obtain top material for it. Oh it's a factory Shaker car too!!! He got his tag decoded by the Guru years back and that's how he even realized what he had. Ron
Legendary Gator Grains are running $1200+ last I recall
[Re: 6bblgt]
#1553347
12/30/13 11:33 PM
12/30/13 11:33 PM
Posts: 777 Washougal,Wa
Dodge
Washougal,Wa
Did they make a black Gator Grain Top? I ask because I have a 70 Sunroof Charger so theres no code on fender tag. I've talked to a few owners from the mid 70s and they all say it was a Gator Grain top. When I bought it, it came with a roll of black Gator Grain vinyl. Thanks
Stand behind your word
[Re: Dodge]
#1553348
12/31/13 12:02 AM
12/31/13 12:02 AM
Posts: 1,652 Calgary, Alberta Canada
m46rat
They only came in one color, but I think the generally accepted wisdom is that they turned black because of the sun beating down on them after a certain time. If your car was a gator top car it would have the V1G code on your fender tag and also on the broadcast sheet.
[Re: browndevil]
#1553349
12/31/13 01:10 AM
12/31/13 01:10 AM
Posts: 1,028 NB, Canada
moparfan53
NB, Canada
What color is the gator grain top? Its hard to tell from the pictures (black or brown)?
Michael
When looking at the samples in the '70 dealer trim book, you can see the brown in the gator grain compared to the black above it (when new of course, as already mentioned it changes with age/exposure).
[Re: cdstl]
#1553354
12/31/13 07:06 PM
12/31/13 07:06 PM
Posts: 11,022 Farmington, CT
KISSAlien
Farmington, CT
They do tend to turn black....
That's because technically they are black. Then a brown dye covered it. This dye tended to wear off which left the black vinyl underneath it to show.
[Re: 6bblgt]
#1553355
01/02/14 08:19 PM
01/02/14 08:19 PM
Posts: 1,995 Apollo, PA.
B1MAXX
Apollo, PA.
Would you be so kind as to list the make/model of these 5?
1 - JS29U0E108xxx E86 D32 FK5 V1G HRX9 H51 V21 V5X 2 - JS29U0E129xxx E86 D32 EB5 V1G H5B5 V6X 3 - BS23R0B159xxx E74 D32 FC7 V1G H6X9 4 - BS23V0B178xxx E87 D21 FT6 V1G H6X9 A34 5 - JS23V0B184xxx E87 D32 EW1 V1G H5X9 A32 V?? 6 - BS23R0B222xxx E74 D21 FE5 V1G PRX9 A33 V5X
here is one I know of
[Re: EV2RTSE]
#1553360
01/03/14 12:44 PM
01/03/14 12:44 PM
Posts: 1,025 NJ
EV2RTSE
NJ
