Re: Low Dodge
[Re: fstfish66]
#1553286
03/14/14 03:39 PM
03/14/14 03:39 PM
Posts: 10,538 Freeport IL USA
poorboy
Freeport IL USA
The black truck pictured is a 54. 54 was the first year for the curved 1 piece windshield. That windshield was used for the 54 model year, and until the month of May, just passed 1/2 through, the 1955 model year, when the cab was reconfigured and the door posts were stood straight up and the windshields wrapped around to the door posts. The wrap-a-around windshields went unchanged through the 1960 model year. The 1st truck pictured on this thread is a late 55 or 56 cab. You can clearly see the differences between the 2 windshields.
That 54 & early 55 windshield was hard to find, and expensive new, over 15 years ago. New versions were over $500, 15 years ago. I have to wonder if new 54 windshields are even available new any more.
The blue truck Bigdad posted, just before the 2 pictures of the black truck is a 53. Other then the shape of the grill opening, and grill, and the box fenders, the 48-53 trucks are very similar. The 53 would have been the last year for the split windshields. You can also see the differences in the nose piece between the hood and the headlights, on the 48-53, that area rises up, on the 54-56 it dips down. Harder to notice is the differences in the height of the hood, to top of fender, when comparing the 53 to the 54-56 trucks. The 48-53 hood is a couple of inches higher then the fender tops on the 54-56 trucks. I also believe the roof height on the 48-53 trucks are higher then the 54-56 and newer trucks are. Gene
Re: Low Dodge
[Re: bigdad]
#1553298
06/11/14 04:54 PM
06/11/14 04:54 PM
Posts: 10,975 Nort Cackalacky
rrbrucea
Member known as the "Artist"
Nort Cackalacky
Not my style but ..
There's one of these (a STOCK one that is) just sitting out behind a house in my neighborhood. Not 2 blocks from my place. I don't dare stop and ask if they'd sell it for fear it would follow me home.
Re: Low Dodge
[Re: demon]
#1553304
08/10/14 06:44 PM
08/10/14 06:44 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
I saw that last 57 at a diesel event a couple of years ago. It is on a late model cummins truck frame and drivetrain. They widened all the fenders.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: Low Dodge
[Re: rattler]
#1553305
08/21/14 04:57 PM
08/21/14 04:57 PM
Posts: 321 Massachusetts
Sneke_Eyez
Massachusetts
And darn if it doesn't look amazing! Drool!
1969 Satellite Wagon - G3 Hemi Swap Incoming. | 1969 Coronet Post Coupe. 2002 Intrepid ES | 2009 Ram SLT | 2004 300M Special | 2002 300M Pro Am - Hers
Are you a New England Mopar Enthusiast? Come check out the revived NorthEast Mighty Mopar at www.northeastmightymopar.com!
