Quarter Panel Bonding Procedure
#15523
06/03/05 07:09 AM
06/03/05 07:09 AM
Posts: 2,908 Franklinville,NJ
JeffsCustomPaint
Franklinville,NJ
Alot of you People building your own cars requested the process to attach skins using Panel Bonding Adhesive. Quarter Panel Bonding Step 1. Remove all trim and any glass that needs to be removed. Step 2. Jack vehicle up in rear and support body with jack stands(try to make car level) remove wheel. Step 3. Look at new panel and determine attachement points and seams. Using a grinder(air powered is best) with 24or 36 grit disc,grind paint off at any seams where new panel must attach, grinding lead out of seam exposing spot welds(not necessary on partial 1/4) Step 4.Using a spot weld drill bit,drill out spot welds. Drilling spot welds A. Using a wire wheel on drill or die grinder remove paint exposing any spotwelds that you may not see,or covered with paint on all seams. B. using a centerpunch,punch the center of all spotwelds. C.Using a spotweld cutter(Blair,Blair RotaBroach) Drill panel till it goes thru one thickness of metal.Drilling out each weld. Spotwelds are located on all seams,wheel opening, and joints.Do Not Drill Thru Metal All The Way.
D. Using a flat scraper or chisel and hammer, slide between the two metals and pry the two layers of metal.If metal doesn't pop apart,look for a weld you missed or not drilled deep enough. you may have to chisel between welds to release if small bit of metal is holding panel.
Step 5. After drilling all welds look for any spots that may have been brazed(brass welding) if you find take a torch heating brass and using a small prybar or scraper lift on panel while heatng(Caution,Do Not Get Metal Red Hot) torch should melt brass and release panel.
Step 6.Remove old skin. Taking a hammer and dolly.Straighten any edges that may have gotten bent during removal.
Step 7.Grind smooth and remove paint from all welding flanges and seams.
Step 8.Fit new panel in place making sure edges and body lines match adjacent panels. Hold in place using clamps or cleeko pins. Cleeko's are good for realigning panel during bonding process. On the back seam along rear bodypanel,drill some 5/16ths holes into 1/4 skin for plug welding it to rear body panel later. (stitch welds can be used instead also) Step 9.Remove new panel and place face down. Take ginder and remove black E-coat around inside edges(panel mateing surface)grind coating off about half to three quarters wide. Step 10.Apply a bead of Panel Bonding Adhesive around inside edge of 1/4 skin, using a plastic spreader, spread adhesive smooth covering all bare metal.
Step 11. Apply bead of adhesive on body flanges where 1/4 skin meets,and smooth also like above.
Step 12. Apply 1/8in. bead of adhesive around body flange surfaces. Step 13. Place 1/4 skin on car aligning panel to adjacent panels,making sure gaps are even and bodylines line up.Then clamp in place using vice grips or cleeko holding pins. Let panel dry according to adhesive instructions. Plug or stitch weld the rear body joint after the adhesive has cured. Partial 1/4 skin supplement A. When removing old 1/4 skin cut along edge of 1/4 leaving approx. 2 inches extra metal underneath where top edge of partial skin stops. B. Remove old skin and place partial skin in place,aligning panel to adjacent panels. C. Taking 3/4 masking tape,tape along edge of partial skin (tape above partial 1/4 edge) D. This step requires a flanging tool (Air operated or hand pliers)Flange a piece of scrap metal.Measure from edge of metal to where crimp in metal is.Using this measurement mark old 1/4. E. Measure from edge of tape down to the above crimp width measurement.cut excess metal off to bottom of new mark. F. Flange metal along length of old 1/4 at edge. G. Place new partial skin in place,align panel and check to make sure edge of panel sits flush in flange.(trim edge of 1/4 skin if necessary) H. Clamp new panel in place(aligning gaps and body lines) drill 1/8th in. holes thru 1/4 skin along seam halfway down from edge of old and top of new panel.Secure with cleeko pins or screws. I. remove panel and grind coating off inside of partial 1/4 approx. 1/2 in. down from edge. grind any paint along old 1/4 edge. J. Apply a liberal amount of adhesive to both old 1/4 and new skin using same method as above mentioned process. apply the 1/8th in. bead of adhesive along flange and place 1/4 skin in place. K. align skin and put cleeko's or screws in excisting holes along seam.Use Above method for attching the other areas of 1/4 skin. Let adhesive dry then smooth seam with grinder. (Weld rear body seam as mentioned in above) L. After removeing cleeko's and smoothing seam with grinder,apply a coat of either Duraglass filler or All Metal filler over seam. smooth seam straight with sanding block and 36 grit sand paper. M. Finish seam with body filler then sand and prime panel.(Inside trunk seam of 1/4 can be smoothed over with above method then sprayed with Paintable Rubberized Undercoating & Painted)
Tools and Materials Required 4-5 in. grinder with 24or 36 grit discs
Panel Cutter(cut-off tool or shear type)
Flat scraper or chisel
Body Hammer and Metal dolly
SpotWeld Cutter( Blair double blade or Blair RotaBroach Cutters work best)
Cleeko panel holding pins or 1/8th in.screws Cleeko Pliers
Flange Tool (Air operated or hand pliers)
SEM or 3M Panel Bonding Adhesive & Applicator gun (SEM applicator gun is cheapest-Approx. $60) (3M App. Gun is Approx. $130-$150) Wire Feed welder for plug or stitch welding rear body seam. 3/4 in. Tape Pencil or Marker(Sharpie) Sanding Block and 36 grit paper Duraglass or All Metal filler Body filler and Sandpaper Paintable Rubberized Undercoating
Re: Quarter Panel Bonding Procedure
[Re: JeffsCustomPaint]
#15524
06/03/05 01:17 PM
06/03/05 01:17 PM
Gotta Love that cut and paste ehh Jeff!
#15525
06/03/05 01:32 PM
06/03/05 01:32 PM
Posts: 1,151 Las Vegas
afxcoronet
Las Vegas
Thank you for that, I have a '66 satellite that I'll be using those procedures on, later this summer. Now if I could only find complete rear quarters for the thing. Curtis
Taking over the World one win light at a time.
[Re: IMGTX]
#15528
06/03/05 05:22 PM
06/03/05 05:22 PM
JMHO
I wouldnt use bonding on old Muscle..I/E Torque in these cars have been known to buckle stuff up..lol Like Passanger side floor pans which B bodys are famous for. But for Show cars an such, I guess it would be ok.
[Re: chewy]
#15529
06/03/05 06:20 PM
06/03/05 06:20 PM
Posts: 13,878 Willow Grove PA
71sat440
Willow Grove PA
Does a bonded quarter reduce the value of your car? How well does the bond hold up over time and heat and/or accidents?
Well if I believe the rep that sells the stuff to me, he says you can take two pieces and overlap them 1/4 inch with the adhesive then play tug-o-war with the metal between two frame machines and the metal will tear before the adhesive. As far as acidents we were told never to use the stuff on frames etc as it will be strong enough to eliminate the crumple zones. Can't answer as far as heat (or cold for that matter) or value but consider the following.
No gaps between spotwelds, a 100% seal all the way around, no place for moisture to hide between panels.
No laying down on your back trying to mig over your head. No grinding down spot welds, which not only saves time but $ in discs. The most heat generated is from grinding the surface to be preped, no welding near flamable stuff or worrying about catching carpets on fire etc. Other then trying to duplicate the look of a factory spot weld, I see no advantages of welding over the adhesive unless you are good enough to butt (SP?) weld. Just my but I havn't used the stuff since I left the bodyshop a few years ago, If anything I'm sure theirs alot of improvents since I've used it.
[Re: 71sat440]
#15530
06/03/05 06:33 PM
06/03/05 06:33 PM
Posts: 2,966 Wendy, I'm home.
dstryr
Wendy, I'm home.
What's the lifespan now days of adhesive? I talked to a guy in Colorado Springs a few years ago about my A12 and he said 20 years.....
I told myself 'No way am I going to use adhesive if I'll have to redo this car because the glue won't last.'
dstryr, since 1986.
#15531
06/03/05 08:54 PM
06/03/05 08:54 PM
JeffsCustomPaint
Franklinville,NJ
Rich, Sorry,I didn't understand your statement. You were being humorous,I go it now. thanks,Jeff
#15532
06/03/05 08:59 PM
06/03/05 08:59 PM
Posts: 4,872 connecticut
pnypwr
connecticut
i think what he meant was cut off the old one paste on the new one! I dont think it was a personal attack on your procedures! However I too wonder about the strength of panel bond will it hold up against the torque of a big block and stick in a race car?
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
[Re: pnypwr]
#15533
06/03/05 09:15 PM
06/03/05 09:15 PM
Naw..Nothing personal Jeff.. But yeah I dont think Id use bonding ( Glue ) on high end muscle, just personal choice.
#15534
06/03/05 09:24 PM
06/03/05 09:24 PM
JeffsCustomPaint
Franklinville,NJ
Ok,All you others. The stuff is tuff as nails and ten times stronger. I had to replace a quarter on a car that was wrecked and it previously had one bonded on. Lets say the metal ripped everywhere but where the adhesive was.You can bond the metal together and clamp it to 2 pulling posts and it will tear the metal before the bonded area. I know this for a fact we did it in the bodyshop I used to work at to see.Back to the above mentioned car I had a heck of a time getting off the rest of the metal to bond a new one on. You can put some plug welds on the rear at the rear body panel joint or in door jamb,but that is the only places you will ever need to. They only recommend that due to they are CYAing themselves for future lawsuits.Trust me this stuff is very durable and is tuff. Welding a partial quarter you will warp the metal the length of it.Even the best welders get warpage on sheetmetal.This method illiminates any possibilty of that happening,resulting in less bodywork required on the seam. I never indorse products I don't have experience with,and know how good they are. I have been doing this method for about 8 years. And yes Rich it will take Torque,remember a frame machine has 5to 10,000 psi of pulling strength. This product is for sheetmetal and none structure areas.you can't bond a framerail,and you still need to plug weld the floorpans to the framerails. It is used for 1/4 and door skins or even metal patch panels.It's not ment to replace all welding.
Have fun Bonding everyone,there is the procedure now you can use it if you like. Not like the product sells these detail instructions.
-Jeff
[Re: max]
#15536
06/03/05 11:00 PM
06/03/05 11:00 PM
I'll take mine welded please.
#15537
06/03/05 11:14 PM
06/03/05 11:14 PM
Posts: 1,037 Texas, Dallas
G_T
Texas, Dallas
Same here. See pic for Clecko's in action. Don't buy them from Eastwood as they charge 6X the price. Find new ones cheap on the internet. The bonding works very well - but I wouldn't use it on an entire quarter. It's way to difficult to line and hold everything in place on such a large/complex panel. I wouldn't hesitate to use it on small patch panels and such... Of couse, now that I have a mig and can do it why bother...
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com
2012 Charger SRT8
#15539
06/03/05 11:39 PM
06/03/05 11:39 PM
JeffsCustomPaint
Franklinville,NJ
Russ, that is fine,but look how far you grinded metal. was there any warpage?Plus you tack welded the whole seam and it looks like there is gaps between your welds.Mig welding burns off the coating between the two metals,and that is where the rust will start to form and work it's way thru in time.It is impossible to get anything in between the two metals to stop the rust and protect it.Every welded patch I ever replaced started rusting from the welded seam.
In my method the adhesive seals the two metals and provents warping from welding. I used to do it that way but is less work bonding. Welds take alot of time to grind down. bonding there are no welds to grind.
G_T, You can bond a whole 1/4 and align it. you will need clamps and cleeko's to hold it either way you do it. Prefitting the panel is what makes it possible. with cleeko's the holes are there to make sure the panel goes back in the right place. You have time to move the panel in place till the adhesive dries. wasn't sure where else to buy cleeko's.I use screw's, it will pull the panel together better sometimes.I did mention using screws as an alternative.
To the rest who are negative about using this method,Don't knock it till you try it.
Thanks,-Jeff
#15540
06/03/05 11:43 PM
06/03/05 11:43 PM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
Jeff- Thank you very for documenting the proceedure for the bonding process.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
[Re: Mr440GSS]
#15542
06/03/05 11:58 PM
06/03/05 11:58 PM
JeffsCustomPaint
Franklinville,NJ
Thanks, well the plug welding is for CYA purposes maybe i'll edit the procedure and add that in. They say to do that in case a vehicle hits the rear and tries to tear the panel off. We tested the stuff,tack welding vs. bonding The tack welds broke when pulling apart. bonded metal ripped off at the clamp holding the metal not the bonded seam. BTW,the factory seam on full quarters can be bonded if you want.like I said 3M is covering thier butts. If you can bond the rest you can bond that too. No one has to use this.I was requested by many other members to post the procedure and thats what I did. Yes it is alot easier once you have done it.
