Re: Big block 4 -speed pilot bearings
[Re: az426john]
#1552899
12/25/13 03:01 AM
12/25/13 03:01 AM
Posts: 259 Khemi, Stygia
Mebsuta
Khemi, Stygia
Is the crankshaft actually drilled for a 4 spd input shaft and pilot bushing? Not all of them were.
68 Roadrunner. 383 4-spd. Beat up.
[Re: 70Cuda383]
#1552901
12/25/13 05:05 AM
12/25/13 05:05 AM
Posts: 5,166 CT
GTX MATT
CT
Yes, it sounds like your crank isn't finished drilled for a four speed. For some reason Chrysler rough drilled all cranks but didn't finish drill them for the pilot bearing. Just get the bearing that goes in the hub. I bought mine from Mancini, but lots of places have them. Just make sure the crank is drilled DEEP enough, sometimes they aren't drilled deep enough either. If not you can drill it deeper or trim the input shaft on the tranny. http://chucker54.stores.yahoo.net/marapibe.html
